Results 1 to 5 of 5
Thread: Help with mainspring winder
    jock72681 Guest
    Default Help with mainspring winder
    Does anyone know if k&d 126 and k&d 128 are suitable for 12s to 18s pocket watches?
    jock72681 Guest
    jock72681 Guest
    I also see a k&d 123 set adjustable up to 11mm. is that big enough?
    Jock,
    Either the 126 or the 128 will be just fine for pocketwatches.
    Vic
    jock72681 Guest
    Thanks vic,
  1. Newbie needs help with spring winder
    By Gary Walker in forum Clock Repair
    Last Post: 05-09-2011, 11:10 AM
  2. Help with Mainspring size ?
    By Shogun in forum Clock Repair
    Last Post: 12-25-2009, 10:16 PM
  3. Need help with mainsprings for automatic watches
    By Phillip W in forum Watch Repair
    Last Post: 08-18-2006, 12:16 PM
  4. Help with Mainspring length for Seth Thomas 124 movement
    By ChrisBeattie in forum Clock Repair
    Last Post: 06-23-2006, 12:44 AM
  5. Newbie Needs Help With Mainspring
    By Larry Wilson in forum Watch Repair
    Last Post: 03-25-2006, 09:43 PM
