NOTICE Notice: This is an old thread. The last post was 4525 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 9 of 9
    Default Old Double Cuckoo Clock
    Hi,
    I have an older Cuckoo Clock that has two Cuckoos. The only identifying mark on the movement is the letter "H" which is engraved into the back plate.
    I am posting a picture of the clock and would appreciate any information that anyone might offer as to the age of the clock and it's manufacturer.
    I also have a smaller version of this same clock with a single cuckoo. That clock has no identification on it at all.
    Thanks in advance for any assistance provided.
    Ed Patnode
    Default Old Double Cuckoo Clock (By: Ed Patnode)
    Hi,
    Ed Patnode
    Registered User Tom Kloss's Avatar
    Dec 2003
    N.E. Pennsylvania
    1,858
    Hi
    Looks like a nice clock
    It looks like a Quail Cuckoo. With Quail Cuckoos one of the birds sounds on the once on the quarter, twice on the half, three times on the threequarter, and 4 times on the even hour and then the Cuckoo sounds the hour count.
    Tom
    Sometimes you just don’t know if your being rewarded or punished
    Apr 2004
    Mesquite, TX
    938
    Kloss' probably correct: "Quail cuckoo". Had one here for awhile but not long. WAAAY too much chirpin' fer me. "H"? Probably "Herr" - Hubert Herr mebbe . I find Herr to be a better quality movement than regulas.
    Michael Vala
    Guest
    Definitely a cuckoo and quail (will have 3 bellows in it) and my best guess is that this is a Kiehl, probably 1900 or so, possibly earlier. Have you removed the movement? Sometimes there are markings on the front, but usually it is only "Germany" stamp. Some things to look for which may indicate maker: How are the birds mounted on the rod. Do the flute tubes have a mounting block or are they fixed (typically) with a screw in the flute tube itself. What is the chain (links per foot) and weight size?
  6. #6
    Ed,
    Dating a BF Cuckoo can be hard at times...
    Some of the Black Forest clock makers made their clocks with the most current trends, while others continued to produce them "they way they were taught" or "how there father made them"... so the rules used to date them are not always 100% but they can get you close.
    It would be best to see a picture of the movement, and a little more info.
    Your cuckoo clock case (railroad gate style) was very popular in the early 1900's.
    I have several old Black Forest catalogs from around 1900 to 1910 most of the cuckoos being sold look like yours.
    To help you date it, please post the following info:
    Is movement cast brass or was it stamped?
    Are the plates pinned or were nuts used?
    Also look at the bird... Is the bird wood? Is it well made, and real looking or does it have sharp edges and is "box looking"?
    What about the perch? Wood or brass?
    Is there any plywood on the case?
    From there we can get you in a close range of when it was made.
    Justin
  7. #7
    Thanks to all for your responses.
    I am attaching an additional picture taken from the back of the movement.
    The plates are brass and appear to be stamped.
    The movement is assembled with nuts, not pins.
    The birds both appear to be well made with wings and beaks that move as the bird cuckoos. Their perches ar wooden.
    There is no plywood in the case.
    The chain link count is 48 per foot.
    Thanks,
    Ed Patnode
  8. #8
    I forgot to attache the picture......
  9. #9
    Registered user. Mike Phelan's Avatar
    Dec 2003
    West Yorkshire, England
    9,823
    Hi Ed
    Definitely a quail clock, and very nice, too!
    Mike - banned member of the throwaway society. :o
  1. Schneider Regula Cuckoo Clock New? or Old?
    By eragene in forum Clocks General.
    Last Post: 01-05-2006, 01:57 PM
  2. bellows for old badische cuckoo clock
    By randy laham in forum Clock Repair
    Last Post: 12-09-2005, 07:47 PM
  3. old self cuckoo clock
    By randy laham in forum Clocks General.
    Last Post: 08-22-2005, 08:44 AM
  4. old and odd cuckoo clock movement..
    Last Post: 07-04-2005, 10:32 PM
  5. old cuckoo clock case paint???
    By randy laham in forum Clock Case Restoration and Repair.
    Last Post: 06-24-2005, 10:14 PM
