Results 1 to 4 of 4
Thread: Another moronic question from a newbie...
    railman Guest
    Default Another moronic question from a newbie...
    What's a melamine dial. I know the older dials were porcelain on copper. Is the melamine dial something the watch makers used in later years or is it a repro? How do you tell? I've read threads that had pics of watches that were very early and some of you mentioned it was a "melamine" dial. Thanks for any info...
    railman Guest
    in the mid forties, the wonderous wizards of Hamilton developed the Melamine dial. speculation is for cost cutting measures....
    What it is ......
    A metal backing is covered with a plastic printed material that has the dial design on it.....
    The looked fine when new, but do not age too well, especially when exposed to sunlight,[red numbers faded] and many temperature changes....[cracks]
    This material continued to be used until the end. They even produced Ball dials in melamine.
    It is not a repro dial.... original from factory ......
    how can u tell? sometimes not easy with only pictures.... but a cinch when in hand...
    when off the watch, the back will be black metal, not covered with glaze....
    Chapter 17 North Carolina
    http://www.nawcc-carolina17.org/default.htm
    Chapter 149 Early American Watch Club .. Home of Russ Snyder Illinois CD database and Henry Burgell Serial number Look-up ... excellent research resources!
    http://www.nawcc-ch149.com/ http://www.nawcc-ch149.com/pw_dbresearch.html
    Chapter 149 Mentor List http://www.nawcc-ch149.com/mentor.html
    Lindell V. Riddle Guest
    Jim,
    Only thing I could add to Terry's explanation is that "melamine" or composite dials have a distinctive "grayish" tone whereas a porcelain dial is very white. Bear in mind they are correct and original and we are already seeing that when in top condition they command a premium. On the other hand the scratched, chipped and faded ones do not appeal.
    There's nothing "moronic" about your questions Jim, you have raised some very important and interesting issues recently. And by the way, you are a "novice collector" and you'll soon be out of even that category, you're learning fast!
    Best Wishes,
    Lindell
  1. iTR questions from a newbie
    By Twnhstnut in forum Clock Repair
    Last Post: 02-02-2012, 09:49 PM
  2. Pendulum Question from a Newbie
    By CECat in forum Clock Repair
    Last Post: 09-10-2011, 12:25 PM
  3. Just a few questions from a newbie
    By mwmwall in forum American Pocket Watches
    Last Post: 01-31-2011, 10:07 PM
  4. Hamilton Question from a Newbie
    By SteveE in forum American Pocket Watches
    Last Post: 05-03-2004, 08:21 AM
  5. quick question from a newbie
    By David Thomas in forum Wrist Watches
    Last Post: 07-04-2002, 01:37 AM
