Goal: $300, Received: $40.00 (13%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1559 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    jparker
    Guest
    Default Seth Thomas movement 89?
    I bought a Seth Thomas movement which appears to be unique. The movement is a bim-bam strike with a rack and snail. the snail has grooves that allow the clock to strike the quarter hours. One bim-bam on the quarter. Twice on the half and three times on the three quarter. Then the hour. On the leg is marked 89 with something after that that I cannot make out. Possibly a 0 however looks like a backwards J. Seth Thomas is marked in the upperleft corner. Can anyone tell me about this movement and what clock it would have been installed in. Thanks Jim
    jparker
    Guest
    jparker
    Guest
    I checked the find feature and found additional info on this movement. Does anyone know what type of case(s) these would have been installed in? Thanks Jim
    jparker,it is called a 1/4 hour bim bam and I have seen it in many Plymouth tambour clocks.
    Mike C.
    aka clock whisperer
    Default Re: Seth Thomas movement 89?
    Mike, I have this same movement from a Plymouth clock. I noticed in another of your posts that you believe this movement takes a 5/3 double-ended key. Is that correct? I need one. Thanks!!
  6. #6
    Apr 2002
    19,722
    Blog Entries
    You may notget a reply from Mike, this is a old thread.
  1. Key for Seth Thomas no. 89 movement
    By Seth Thomas Fan in forum Clocks General.
    Last Post: 03-31-2006, 12:07 PM
  2. Seth Thomas movement - 89 vs 89al
    By lvan1 in forum Clocks General.
    Last Post: 10-29-2005, 04:31 PM
  3. Seth Thomas movement # 77A
    By BILL KAPP in forum Clocks General.
    Last Post: 05-06-2005, 02:25 AM
  4. Seth Thomas movement
    By David Burgess in forum Clock Repair
    Last Post: 12-29-2004, 02:48 AM
  5. Seth Thomas movement # 61?
    Last Post: 02-11-2004, 01:52 PM
Members who have read this thread: 0
There are no members to list at the moment.
