Goal amount for this month: 300 USD, Received: 230.00 USD (77%) Contribute Now
Donate whatever you can or Join the 16,000 other NAWCC members for only $72 (plus $10 for hard copy publications). Check it out here.
NOTICE Notice: This is an old thread. The last post was 2475 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Registered user. bchaps's Avatar
    Dec 2001
    Mountain Top, PA
    1,127
    Default How do YOU install the train bridge on a Full Plate Pocket Watch movement?
    I'm working on an old Elgin Pocket Watch Grade 184. The Balance wheel is positioned above the train bridge while the roller end of the staff is recessed in a "well" under the bridge. My difficulty is getting the horn end of the pallet fork into the "well" while attempting to assemble the train bridge. I'm sure there is a technique to do this, but I haven't discovered it yet.
    Your comments are always appreciated.
    Bill
    Bill...
    Member Chapter 1
    Dec 2001
    Mountain Top, PA
    1,127
    Bill
    Bill...
    Member Chapter 1
    Registered User doug sinclair's Avatar
    Aug 2000
    Calgary, Alberta
    10,209
    Bill,
    Here's how I do it. This is from a BULLETIN article I did on a Hamilton 927 a couple years ago.
    assembly
    1/ Assemble as shown.
    2/ Line up the recess in the pillar plate over the bridge as shown.
    3/ Lower the pillar plate, watching for the centre wheel arbor to appear in its bearing.
    4/ Now, make certain that the pillars on the pillar plate are aligned with the holes in the bridge correctly.
    5/ Continue to lower the pillar plate, observing the orientation of the pillars to the holes in the bridge.
    6/ Now watch for the fourth wheel pivot to appear at its bearing, line up, and lower pillar plate further.
    7/ Now, keeping the plates together, you can pick the movement up and aligne everything else.
    By the way, the watch movement type is called "full plate", and the recess for the bottom of the balance staff is called a "potence"> We really gotta get you into the NAWCC where you'l see operations like this easily followed in the BULLETIN!
    Dec 2001
    Mountain Top, PA
    1,127
    Wow! Just assemble on the bridge...simple. Unless, of course, one doesn't think of it! Although I have a complete collection of Bulletins since 1988, knowing how to search the online index for a topic such as this is key.
    By the way, I am a card carrying, dues paying member of NAWCC ... for about six years now, along with Chapters #1 and ####. The bulk of my client work is clocks, so watch repair is still a challenge to me. But, I greatly appreciate your help when I find myself in a corner.
    Doug, Thanks again!
    Bill
    Bill...
    Member Chapter 1
    Aug 2000
    Calgary, Alberta
    10,209
    Bill,
    You might want to update your personal profile with the information that you are NAWCC. It doesn't say, so I assumed you weren't. Anyway, the complete article I mentioned on the re-staffing, tear-down, recondition, and re-assembly of the full plate Hamilton 927 is in the BULLETIN issue 352, and 353,October and December of 2004. Perhaps your earlier interest primarily in clocks meant you weren't reading watch articles back then? Anyway, I cover this topic at length in those two articles.
    By the way, the article also discusses the right way to dismantle a full plate watch without the danger of snapping a pallet arbor pivot! MOST IMPORTANT!
  6. #6
    Registered user. neighmond's Avatar
    Jan 2003
    Rural Iowa
    877
    Put it together upside down!
    Plant the wheels and lever in the upper plate and lower the dial plate upon them.
    Every man must have a purpose to strive for, A cause to fight for, A dream to live for, Because A Man without a Dream is Dead
  7. #7
    Apr 2002
    15,624
    Blog Entries
    A full plate is really not much more difficult.Just a few things to watch for.Doug,s articles are well written and illustrated.
  1. How do you set the second hand on a lever set pocket watch?
    By old goat in forum American Pocket Watches
    Last Post: 08-12-2012, 01:30 PM
  2. Replies: 8
    Last Post: 11-28-2011, 02:48 AM
  3. How do you set the alarm on a Gingerbread?
    By It's About Time in forum Clock Repair
    Last Post: 09-26-2007, 06:57 PM
  4. How do you restore the brass looking base?
    By shutterbug in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 06-04-2006, 04:52 PM
  5. how do you hook a spring back on the winding arbor?
    By SrWilson in forum Clock Repair
    Last Post: 09-07-2005, 03:46 AM
