Goal: $300, Received: $215.00 (72%) Contribute Now
Results 1 to 5 of 5
    G. Waite
    Guest
    Default Schatz 1000 day clock
    Hello, I,m looking for any parts and or info. that will help me to restore a Schatz 1000 day anniversary clock.
    It is large brass and glass cased carraige style clock, key wind , and in dire need of some T.L.C.
    thankyou Graham Waite.
    Default Schatz 1000 day clock (By: G. Waite)
    Graham,
    The Horolovar 400 Day Repair Guide by Charles Terwilliger (10th Edition) would be the book you need. It gives a good write-up on how to restore your clock.
    The parts that you would most likely require would be the suspension spring (.0024 inch or .061 mm),21 X 50 mainspring, top/bottom blocks and forks. All these are available from the clock spare supply houses.
    The Horolovar Company
    Box 264, St, Claire Shores, MI 48080
    Phone: 313-882-9380
    Fax: 313-882-9381
    S LaRose http://www.slarose.com
    TimeSavers http://www.timesavers.com
    Merritt's http://www.merrits.com
    You are also welcomed to join NAWCC International 400 day Chapter 168 which will have lots of information with regards to Torsion clocks. Contact Mr.John Hubby at pastimes@juno.com for membership information.
    Vic
    NAWCC Life 205
    Member Chapter 168
    [This message has been edited by Victor Tang (edited 09-22-2000).]
    G. Waite
    Guest
    Vic, Thanks for the info.
    I've just ordered the book, sounds like just the one I need.
    Graham.
    Registered user.
    Sep 2016
    Madera CA
    118
    Default Re: Schatz 1000 day clock (By: G. Waite)
    The pivot on the mainspring barrel and first wheel sometimes shears as there is a tremendous amount of stored energy.
    Easy to fix by first locating a drill bit that fits the hole in the plate then place shaft or pivot in a lathe and drill center in pivot.
    Cut end off drill and epoxy in place.
    Registered User richiec's Avatar
    Feb 2007
    Brick, Ocean, NJ
    5,424
    Blog Entries
    Default Re: Schatz 1000 day clock (By: TQ60)
    TQ60, this thread is 16 years old, don't think Mr.Waite is still here.
  1. Schatz 1000 day clock- level adjusters
    By powertop10 in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 10-11-2011, 10:20 PM
  2. Schatz 1000 day clock
    By mr.jeepster in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 08-17-2009, 04:02 PM
  3. about 1000 day clocks
    By Gianluca in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 12-06-2006, 09:13 PM
  4. schatz 1000 day clock
    By pilotmotor in forum Clock Repair
    Last Post: 04-28-2006, 12:17 PM
Members who have read this thread: 3
