NOTICE Notice: This is an old thread. The last post was 4827 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Default Repair of PAM electric movement for Coca-Cola clock
    where can i get the electric movement for a 1952 Coke clock manufactured by the PAM Clock Co. of Brooklyn, NY?
    where can i get the original repaired?
    Default Repair of PAM electric movement for Coca-Cola clock (By: john foote)
    Registered user.
    Mar 2004
    Memphis Area, TN, USA
    490
    John,
    Try Slarose.com They have electric movements and just he motors. Hope this helps. Don
    Dear John,
    I too had a pam ad clock with a Hastings piston rings face and the cust wanted it fixed, I could not find a good replacement motor and gear box, with the cust permission I replaced it with synchron type C from timesavers, I had to build mounting posts to space it from the back, I used a #20069 bottom set with a 1" tube. You may need to modify the second hand to fit by tapping it to the right thread size.
    Hope this will help.
    David
    dlewis@overland.net
    NAWCC #158433
    mrb
    Guest
    i saw a lanshire movement in timesavers that is a replacement for the pam ad. don't know anything about it. hope it is better than the junk replacement that is being sold as a telechron unit replacement. that is a total waste
  6. #6
    Richard Warburton of Skykomish, WA can repair the PAM motors and movements. i found this somewhere else on the message board but can't remember where. i spoke with him by phone yesterday and mailed a motor/movement combo to him today. i will post the phone number and PO box tomorrow.
    the phone no. is 360-677-2254 and the address is POB 149, Skykomish, WA 98288.
    john
    [This message was edited by john foote on March 11, 2004 at 11:12.]
  1. Source For "Coca-Cola" Glass or Transfer
    By Randy Johnson in forum Clock Repair
    Last Post: 05-21-2012, 04:05 PM
  2. repair of Sessions type rotor for Mastercrafter
    By wilhelm2 in forum Electric Horology
    Last Post: 02-02-2011, 09:02 PM
  3. Need Sessions electric movement for clock
    By Bill V in forum Electric Horology
    Last Post: 04-10-2010, 10:41 PM
  4. Opinions on repair of Welch #46 movement please.
    By wwparrish01 in forum Clock Repair
    Last Post: 02-05-2009, 09:59 AM
  5. Movement for Self-Winding Clock Needed
    By Frank Lindauer in forum Clocks General.
    Last Post: 07-15-2005, 01:23 AM
