Goal: $300, Received: $350.00 (117%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 3869 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    RoGuE
    Guest
    Default Seiko, Lucien Piccard, Bulova
    (In order from left to right) I have a Seiko Sportsman Diashock, Bulova Sea King, and a Lucien Piccard Seashark. The only watch that works is the Seiko, except everytime I try to turn the crown backward to change the date, it unscrews from the watch.
    As for the Lucien Piccard, I can feel the self winding mechanism moving around, but it doesn't run and the crown has been broken off. The Lucien belongs to my father and I just asked him about it and he said it stopped working long ago. I can't seem to get it open though because the is no back to pop off. I assume it is sealed somehow because it says on the back between the lugs, "Deep Water Pressure Tested".
    The Bulova broke many years ago and I can see why. The spring on that big flywheel looking thing broke.
    Could someone tell me the dates on these and if they are rare or even desired?
    RoGuE
    Guest
    Default Seiko, Lucien Piccard, Bulova (By: RoGuE)
    None are extremely rare, although all three are collectible. I especially like the Bulova. All three would probably be worth getting repaired.
    Respectfully,
    Fifty Fathoms
    RoGuE
    Guest
    I had my scanner out again for something else so I figured I would scan the movements. The first is the Seiko. It has a very modern look inside that watch. I still don't don't know how to get the Lucien Piccard open other than I guess you take out the glass? Second is the Bulova. The red line I drew is parrelel to a thin stip of metal held down my one screw and it sits elevate. What is it? When I opened the back I noticed it was all bent out of shape. And the yellow is obviously where the broken spring is.
    Seiko
    Bulova
    RoGuE
    Guest
    Anyone know how much it would cost to replace the spring in the Bulova?
  6. #6
    AnthonyR
    Guest
    The part parallel to the red line is part 11BLC#93 - "Friction spring for sweep second pinion", it should be applying a certain amount of preasure to the end of the sweep second pinion that protrudes from the center of the ruby near the top of your red line.
    The "broken spring" is the hair spring, are you sure it's broken?
  7. #7
    RoGuE
    Guest
    So that strip of metal should be touching that pinion? Is that why the second hand moves so easily when you touch it? It is nowhere near touching it it is so bent.
    The hair spring is definitely broken. I saw a piece of it sticking up.
  1. Need Help to Recognize if This is a Lucien Piccard Movement ???
    By Arvid in forum European & Other Pocket Watches
    Last Post: 10-18-2011, 09:41 PM
  2. Lucien Piccard I.D.
    By Vicki02 in forum Wrist Watches
    Last Post: 09-10-2011, 10:16 AM
  3. Help dating Lucien Piccard watch
    By Theroamer in forum Wrist Watches
    Last Post: 01-14-2011, 03:47 PM
  4. Help w/Lucien Piccard PW
    By vlieger in forum European & Other Pocket Watches
    Last Post: 08-01-2010, 06:36 PM
  5. Lucien Piccard Luccard
    By Steve Maddox in forum Wrist Watches
    Last Post: 03-03-2002, 10:32 AM
Members who have read this thread: 1
