NOTICE Notice: This is an old thread. The last post was 3978 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 15 of 15
    cr1
    Guest
    Default Seth Thomas "89" Mantel Clock
    Folks I'm new here and was hoping to get some information on one of my grandfather's clocks. It is a Seth Thomas Mantel Clock with the 89 works. Can anyone direct me to where I can find out more about this clock with regards to when it was made and what it might be worth?
    I have been scouring the net to learn more about this clock. I did read that the company stamped the bottom of the clock with the year backwards Mine reads 01, so does that mean 1910? I can provide more descriptions and pictures if that helps.
    Thanks for your help.
    cr1
    Guest
    Default Seth Thomas "89" Mantel Clock (RE: cr1)
    Registered user. Chris Radano's Avatar
    Feb 2004
    Pennsylvania
    2,556
    Welcome to the message board. You are probably correct of the date. If you can post photos here, we may be able to tell you the exact name of the model clock you have, and maybe other info., as well.
    cr1
    Guest
    Here are some photos...
    [IMG:left]
    http://i36.photobucket.com/albums/e37/tonkah/Seth%20Tho...k/DSC01271.jpg[/IMG]
    [IMG:left]<a href="http://photobucket.com" target="_blank"><img src="http://i36.photobucket.com/albums/e37/tonkah/Seth%20Thomas%20Clock/DSC01272.jpg" border="0" alt="Image hosting by Photobucket"></a>[/IMG]
    cr1
    Guest
    back
  6. #6
    cr1
    Guest
    side
  7. #7
    cr1
    Guest
    Side
  8. #8
    cr1
    Guest
    other side
  9. #9
    cr1
    Guest
    workings
  10. #10
    cr1
    Guest
    underside
  11. #11
    cr1
    Guest
    01 Stamp
  12. #12
    cr1
    Guest
    89 marking
  13. #13
    cr1
    Guest
    89 marking
  14. #14
    cr1
    Guest
    The underside photo shows a "hole" actually appears to be wear-through by the pendulum needle. My grandfather was very meticulus with this clock as I remember. Although there appears to be lead weight added to the backside of the pendulum.
  15. #15
    Feb 2004
    Pennsylvania
    2,556
    Looks like...a nice example of the "Sentinel". If your clock strikes on a horizontal rod, it is the "Sentinel 9". If it strikes on a spiral gong, it is the "Sentinel 10". Mahogany case. Probably dates to late 1920's. Nice clock, good condition!
  1. Seth Thomas Electric Mantel Clock Advise Please
    By nic walker in forum Clock Repair
    Last Post: 04-16-2005, 12:59 AM
  2. Seth Thomas electric mantel clock
    By Carroll Hardin in forum Electric Horology
    Last Post: 08-27-2004, 01:15 AM
  3. 1894 Seth Thomas Adamantine Mantel Clock Information
    By Captaintrocar in forum Clocks General.
    Last Post: 08-23-2004, 12:17 PM
  4. Seth Thomas 48J mantel clock
    By DML Clocks in forum Clock Repair
    Last Post: 04-26-2003, 10:59 AM
  5. Seth Thomas Electric Mantel Clock Needs Help
    By rleegabe in forum Clocks General.
    Last Post: 10-09-2002, 12:07 PM
Members who have read this thread: 0
There are no members to list at the moment.
