Results 1 to 4 of 4
Thread: Cuckoo clock color
    Sep 2000
    Colorado, usa
    1,208
    usa  us colorado
    NAWCC
    Default Cuckoo clock color
    Tommy,
    I have had some good luck using Flat Enamel from Testors. This is the stuff that comes in the little square bottles and is used for model airplanes, etc. The color that I use as a base is "Rubber". I think it is used for tires on models.
    I have a couple of other colors of the same material that I use to tint the original color.
    I always have my wife check the end results as I am a bit color blind. I am usually surprised at the results.
    Best Regards,
    Dick
    Your local crafts store will likely carry a line of acrylic paints in about a zillion colors (and you can mix to achieve shades not available right out of the bottle). The brand I happen to use is FolkArt. They give a perfectly flat finish, jis' lak' cuckoo brown. For a gloss, there'll also be an acrylic varnish you can mix in or apply on top. All water-cleanup, all water-thinnable (but waterproof once dry). That's where I'd look.
    bangster
    1. Got a question about terminology & what clock parts are called? Click Here.
    Thanks guys for the thread. I was wondering the same thing as well. :biggrin:
  4. Default Cuckoo clock color
    Many times an exact finish or color match can be gotten by taking a sample of the finish to one of the paint suppliers that have the optical color match system. They scan your sample and a computer calculates a mixing formula. The computer will create a dry finish which is very close to the original. You will normally have the choice of paint type ( laytex or oil base) The draw back to this is the smallest quantity that can be purchased is usually a quart.
    Jim DeRosier
    Empire Clock, Inc.
  1. cuckoo clock parts
    By randy laham in forum Clocks General.
    Last Post: 12-07-2005, 05:07 PM
  2. Cuckoo clock color
    By Dick Feldman in forum Clock Repair
    Last Post: 10-24-2005, 03:35 AM
  3. Cuckoo clock weight questions
    By Eckmill in forum Clocks General.
    Last Post: 10-15-2005, 08:46 AM
  4. cuckoo clock large music box w/batt
    By randy laham in forum Clock Repair
    Last Post: 08-10-2005, 10:48 AM
  5. Cuckoo Clock Squeak
    By kirklox in forum Clock Repair
    Last Post: 03-27-2003, 11:27 PM
