Results 1 to 5 of 5
Thread: #1 or #2 Seth Thomas Regulator weights
    Default #1 or #2 Seth Thomas Regulator weights
    Can some one give me the amount of weight that this clock would need to run. Have a movement without any weights
  3. Default #1 or #2 Seth Thomas Regulator weights
    Phil posted a great suggestion for this on Feb 1 of 2003 under "Restoring 8-day weight movement". Check it out.
    Tom T
    Sep 2000
    Colorado, usa
    1,208
    usa  us colorado
    NAWCC
    The standard weight for an original ST#2 with a #77 Movement should weigh just short of 6#
    Thanks Phil and Tom What a great idea!!!!
  1. Seth Thomas Regulator #1 Weight
    By owen.or in forum Clocks General.
    Last Post: 05-12-2013, 01:34 PM
  2. Seth Thomas Regulator #1 or #2- Advice Also?
    By popeye in forum Clocks General.
    Last Post: 06-29-2009, 07:28 AM
  3. Seth Thomas Regulator No. 1 or No. 2
    By ClocksCollector in forum Clocks General.
    Last Post: 05-20-2008, 02:22 AM
  4. Seth Thomas Regulator ID, No1 or No 2?
    By clockpoor in forum Clocks General.
    Last Post: 09-28-2007, 12:04 AM
  5. Seth Thomas Regulator # 1 or # 2
    By harold in forum Clocks General.
    Last Post: 03-21-2004, 10:16 AM
