Results 1 to 3 of 3
Thread: Measuring Collet Size
    Default Measuring Collet Size
    How do you measure to find what the size of a collet is? I am not sure if mine is 8mm.
    Thank You.
    Thank You.
    Hi Ticktock, measure the diameter of the neck of the collet, between the head and the thread, with a micrometer and that will tell you what size collet you have.
    Lofty
  1. Recommended Collet Sizes
    By bbodnyk in forum Horological Tools
    Last Post: 01-27-2011, 10:25 PM
  2. Collet size conversion tables
    By John Echternach in forum Horological Tools
    Last Post: 03-31-2008, 12:46 PM
  3. How to measure pivot size for K & D bushing tool
    By Weight Driven in forum Clock Repair
    Last Post: 12-17-2007, 07:29 AM
  4. 8mm Lathe collet sizes.
    By Jeff C in forum Horological Tools
    Last Post: 06-08-2007, 12:56 PM
  5. collet sizes
    By David Robertson in forum Clock Repair
    Last Post: 07-16-2005, 02:40 AM
