NOTICE Notice: This is an old thread. The last post was 5234 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 9 of 9
Thread: K&D Staking Set
    tymekeypur
    Guest
    Default K&D Staking Set
    Have recently acquired a full K&D Staking Set from a retired watchmaker but the set is numbered w/letter prefixs which have not appeared in any array description that I have seen to date...have searched the net for a chart which will decode the stakes for me...a clock guy looking for help with a staking venture into watches...
    jc #0157194
    tymekeypur
    Guest
    Default K&D Staking Set (By: tymekeypur)
    jc #0157194
    Wynter Sturtevant
    Guest
    Jim,
    That is odd to have a K & D set lettered and not numbered. Are they marked K&D?
    Wynter
    tymekeypur
    Guest
    Sorry Wynter I wasn't very clear...all the stakes are numbered but the numbers are preceded by a letter prefix and all the descriptions I've seen, or found, of the K&D numbering system there are in many cases no letter prefix and, if one appears, the letter follows the number...would like the 'key' so I could sort out what use each is to be
    put...thanks...Jim
    jc #0157194
    Jim - To add to Wynter's note: I have never seen K&D punches that were not marked K&D with a number which on occasion was followed by and A or B. The letter reflected changes in hole sizes probably due to the shift from pocket watch repair sizes to sizes better suited to wrist watch repair.
    Can you provide a sample of the markings on your punches? Then someone might be able to help.
  6. #6
    tymekeypur
    Guest
    K Thanks!...I pulled 5 of the 125 odd stakes from the K&D 'New Style' set @random...they read: A I K&D...A 14 K&D...B 56 K&D (for staking a bomber no doubt )...E 25 K&D...C 30 K&D...etc...
    jc #0157194
  7. #7
    Jim - I have a table listing your punches and stumps. I found 4 of the 5 punches you listed; C 30 was not listed. The C punches range from C 79 to C 88. Interestly the punch number signify the hole or end size by stub gauge on punches with the letters A, B, D, &E.
    If you send me your address I will copy the list and mail it to you.
  8. #8
    tymekeypur
    Guest
    Thanks "dross"...will do...Jim
    jc #0157194
  9. #9
    Spike
    Guest
    dross,
    I'd sure like to have a copy of your list of K&D punches & stumps with letter prefixes. I tried to email you but couldn't figure out how to do it. My email is bluedawg&aol.com. Thank you!
  1. Staking set cleanup
    By 107WestStreet in forum Horological Tools
    Last Post: 05-19-2016, 10:06 PM
  2. K&D vs Marshall staking sets
    By Jim D. in forum Horological Tools
    Last Post: 12-17-2006, 10:18 PM
  3. Inverto Staking Set
    By Jack E Radcliffe in forum Horological Tools
    Last Post: 05-05-2005, 09:29 AM
  4. What is a staking set used for?
    By leehuff in forum American Pocket Watches
    Last Post: 01-09-2003, 11:56 PM
  5. Please advise me on purch of staking set
    By Cary in forum Horological Tools
    Last Post: 07-02-2002, 12:33 PM
Members who have read this thread: 3
