NOTICE Notice: This is an old thread. The last post was 4159 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 9 of 9
    jparker
    Guest
    Default Seth Thomas statue clock
    I recently acquired a statue clock that seems unusual. It has a slate base, above that is a spelter section that houses the clock. On top of that is a statue of a lady with a flute sitting in a chair. (similar to the opera on Ansonia clocks). On the leg of the chair is marked DOR101. This clock has a marked Seth Thomas movement, with a reverse count wheel. I found this movement in the Orchid model Crystal regulator made by Seth Thomas. The movement appears original to the clock due to the mounting brackets and screw holes. The name on the porcelain dial is Mitchell, Vance & Co. N.Y.. I cannot find where Seth Thomas made alot of statue clocks. Can anyone fill me in on this clock and/or Mitchell, Vance & Co. Thanks Jim
    jparker
    Guest
    Default Seth Thomas statue clock (By: jparker)
    Jul 2002
    Maryland
    534
    Jim,
    Seth Thomas & Sons (do a search on this site first)made a lot of statue clocks. Get Tran's Seth Thomas book and check that section out(You are likely to find your clock). I beliieve Mitchel, Vance & Compant was a retail chain.
    Larry
    jparker
    Guest
    I have Tran's first Seth Thomas book and found nothing there. I figured Mitchell and Vance was the seller, however did not know if anyone knew the time frame or area they were located. I will check the site. Thanks Jim
    Jul 2002
    Maryland
    534
    Jim,
    Try Trans vol 2 of american clocks pg 295. Clock no 8026 18 inches high, slate base, flute player, 1876 Seth Thomas, sons & co.
    Larry
  6. #6
    Jul 2002
    Maryland
    534
    Jim,
    I did a quick look on the web for Mitchell Vance and saw them listed for New York 1860-1933. I'm sure you could dig deeper for more info if you need it.
    Larry
  7. #7
    jparker
    Guest
    Larry,
    Thanks alot for the info. I have been putting off getting the Vol. 2 but now I am going to have to purchase it. I usually start here at the message board. I usually start at the best point. You have proven that to be the case. Again, thanks Jim
  8. #8
    I have heard that Mitchell and Vance was a decorator shop in New York. Interestingly, they seemed to like to paint the Seth Thomas and Sons statue clocks that Tran shows with a metallic finish. You can find quite a few pictures of these clocks on the Antique Clocks Price Guide site, as well. In addition, try the Find engine on this site for some lengthy discussions of these clocks.
    Pattye
  9. #9
    jparker
    Guest
    I found the information you both suggested. It answered my questions. The clock Larry pointed out was the clock. I have repaired the movement and the clock is up and running. Thanks alot for the information. Jim
  1. Large Seth Thomas Weight Clock not in books
    By Lee Simmons in forum Clocks General.
    Last Post: 01-07-2007, 03:29 AM
  2. Seth Thomas wall clock movement types
    By Seth Thomas Fan in forum Clocks General.
    Last Post: 06-25-2006, 03:22 AM
  3. age of Seth Thomas "school?" clock?
    By Paul FM TX in forum Clocks General.
    Last Post: 04-28-2004, 05:22 AM
  4. Moving Seth Thomas Street clock-expert needed
    By Andy Dervan in forum Clocks General.
    Last Post: 07-30-2003, 07:55 AM
  5. Seth Thomas Ships Clock question
    By John F in forum Clocks General.
    Last Post: 06-23-2003, 05:04 AM
Members who have read this thread: 0
There are no members to list at the moment.
