Goal: $300, Received: $225.00 (75%) Contribute Now
Results 1 to 9 of 9
    Registered User Ron751's Avatar
    Sep 2011
    N. Massapequa, LI, NY
    186
    Default Old style cabinet hardware ???
    I can't find a picture now (of course) but I have seen photos of antique wall clocks that have little devices mounted on either side of the cabinet. Appears to be maybe a L bracket with a set screw ? I'm guessing that these were used to bring the clock away from the wall the proper distance & maybe keep it steady left to right...
    I have a TALL pendulum lock that is very temperamental on the wall. (runs perfect on a test stand). I level/adjust it to run - a few hours later it stops. When I do get it right & running for a long time - I want to put the proverbial screw at the bottom into the wall behind the bob like I've done on my other clocks. The other vital reason for the screw is so the clock doesn't fly away when you open the door to wind......Duh....
    As soon as I touch the screw to the wood with my electric screwdriver, it moves a bit, cause I don't have 4 arms to hold the clock still.
    I think I may have a distance from the wall issue. This was an Emperor kit & there are 4 bumpers built into the backboard screws in the proper locations.
    HOWEVER - for some odd reason there are the ends of the 4 screws w/nuts that hold the movement, protruding from the middle area of the back & they appear to be a few MMs longer than the bumpers - I don't know what Mr. Emperor had in mind but this clock & I are not happy !
    I'm not going to monkey with the screws - there is only ~8MM of protrusion.
    What about over riding the existing bumpers with thicker ones so the clock can lay flat against the wall ? Of course that still leaves a side to side leveling & screw insertion problem.
    "Preparation is nine-tenths of the law" - My father
    Default Re: Old style cabinet hardware ??? (By: Ron751)
    ​You might be able to turn the screws around, so the nuts & shafts are on the inside of the case.
    The man who knows how to make it work will always have a job, The man who knows why it makes it work will always be his boss. Website http://sailorsandsettlersantiques.com
    Default Re: Old style cabinet hardware ??? (By: BLKBEARD)
    Yeah, you don't want them extending beyond the bumpers.
    The bumpers should help keep the clock straight on the wall when they are allowed to do their job. They can also keep it from sliding when you open the door. However, some have preferred sticking a straight pin or similar into the wall at either side to prevent that from occurring. Personally, I just hold the case when I open the door. You could also make a light mark when you get it vertical and in beat so you can set it back easily. Again, personally I just set it by the beat, and when it's right I know the clock is straight again.
    Sep 2011
    186
    I thought of that BB, but the screws are actually threaded rods integrated to a spacer which attaches to the movement and then there is about 10MM of thread poking through the back....heaven forbid that an issue on a clock would be solved that simply - right ? :-}
    Timesavers "wall stabilizers" may be what you're after. Several different kinds.
  6. #6
    Default Re: Old style cabinet hardware ??? (By: bangster)
    ​Maybe if you post a couple of pictures of the Back & the inside, a solution can be found.
  7. #7
    I associate them with Vienna wall clocks
    http://www.m-p.co.uk/muk/parts/chap0...0450000115.htm
    Nick, lots to learn, late starter.
  8. #8
    Default Re: Old style cabinet hardware ??? (By: novicetimekeeper)
    Yep. Timesavers carries those, among others.
  9. #9
    Sep 2011
    186
    Thanks people for your stabilizing suggestions. I ordered a pair right away.
  1. adjusting time on old style hermle 340-020
    By sbwertz in forum Clock Repair
    Last Post: 12-03-2013, 09:18 PM
  2. Hermle floating Balance (old style)
    By matthiasi in forum Clock Repair
    Last Post: 06-26-2012, 05:47 PM
  3. Where to buy old-style carbon-zinc batteries?
    By Chris in forum Electric Horology
    Last Post: 08-24-2011, 06:25 AM
  4. Cuckoo mounting posts...old style
    By gtodude2 in forum Clock Repair
    Last Post: 07-24-2009, 07:43 PM
  5. Old Style Ollie Baker spring winder
    By glr1109 in forum Horological Tools
    Last Post: 02-13-2008, 05:42 AM
