Goal: $300, Received: $275.00 (92%) Contribute Now
Page 2 of 5 FirstFirst 12345 LastLast
Results 16 to 30 of 66
  1. #16
    Default Re: Tool and equipment pointers needed (By: Time After Time)
    I started out with KWM bushings, never saw any reason to change. My first purchase was Timesavers assortment 11604. Lasted a long time.
    My mainspring winder is a Joe Collins. Instructions for making one are in the Repair Hints forum.
  2. #17
    Regarding your current lack of space, I fasten my spring winder to the bench temporarily with C-Clamps. Once you have a spring winder, I doubt that you'll have a need for the small, hand-held contraption but I've never used one so I can't say with any certainty. Seeing that you can use the clock movement itself to wind open springs I would suggest that it would be an unnecessary expense and would eventually become a waste of space in your tool box/shop.
  3. #18
    I use Bergeon bushings simply because I bought their roughly 20 sizes starter box when I first started. If I had it to do over, I'd probably go with KWM
  4. #19
    Yep. But it's cheap, and will work for now.
    Is what I think.
  5. #20
    Quote Originally Posted by bangster View Post
    Is what I think.
    Okay, won't argue with those points ....but....if one can use the Movement itself, how cheap is it, really?
  6. #21
    Dec 2011
    Brockville, On Canada
    5,682
    Default Re: Tool and equipment pointers needed (By: bikerclockguy)
    Biker something that I haven't seem mentioned is a small bench vise. My main go to, use all the time, is a small machinist vise. It has flat smooth parallel jaws with both a vertical "V" and horizontal "V" in the fixed jaw that is extremely useful for hold round stock without using a lot of clamping pressure.
    David
    David S
  7. #22
    Nov 2002
    39,826
    Default Re: Tool and equipment pointers needed (By: R&A)
    Quote Originally Posted by R&A View Post
    It works perfect for what I use it for. But why would you ask this.Oh are you getting a funny. Plus if you look, this movement that I posted about Doesn't have barrel. But I have a Bergeon spring winder, if that satisfies your curiosity. And works well , but also has it's limitation just like any winder.
    So this Bergeon winder won't work with loop end springs? Just asking, I have no experience with it.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  8. #23
    Yes, by all means, a vise. One of mine (I have accumulated several) is a small clamp-onto-the-bench vise with 3" jaws. I park it down at the far end of the bench,
    bring it over in front of me to use, then move it back out of the way.
  9. #24
    Yep, you just have to have at least two good vises. One small one, I use an old ball mounted Pan-a-vise with nylon jaws. And a big honking Ridge all steel vise. I couldn't do without either.
  10. #25
    Default Re: Tool and equipment pointers needed (By: bangster)
    I've seen the "C" restraint clamps for mainsprings, and that will definitely be part of my initial tool order. I hadn't seen a mention of C-clamps to rebush(other than my own); just looking for a little advice from guys who learned the hard way. I will probably try both a C-clamp press-in operation and a tap-in job to see which I like better. The C-clamp is what my instincts are telling me to use, if nothing else than to get the bushing seated correctly before tapping it in. I'll know better when I get started
  11. #26
    Try parallel-jaw pliers. Bushing Using Hand Tools
  12. #27
    Registered User wow's Avatar
    Jun 2008
    Pineville, La. (central La.)
    2,035
    Biker, a set of these are a must. I use them every day.
    http://www.homedepot.com/catalog/pro...2e3cd_1000.jpg
    Will Walker (WOW)
  13. #28
    Best thing to press in bushings is a press. ☺ You can get a decent arbor press (1/2 to 1 ton) for about 30 bucks.
    You will also need a drill press. Get one with a sturdy table and you can use it to press in your bushings.
  14. #29
    Biker: Have you read this? Bushing Using Hand Tools
    i read it, and it changed my life... highly recommended.
    i also went with kwm bushings but am a hobbyist mostly working on my own clocks.
    i collect antique clocks because i get all that extra time...
  15. #30
    Awesome article, especially using the cross-hairs to center the bushing placement. I bought a Dremel tool and drill press type adapter to hold it, so I can get true 90-degree angles at my kitchen table, but the cross-hair trick alone mad it worth the read. I do have a question though. The very last instruction in the article says "Broach and smooth the bush to fit the pivot" Why wouldn't you just use a bushing with an ID that fit the pivot in the first place? I know the ODs are different to accommodate different bushing hole requirements, but aren't the pivots pretty much standardized?
  1. Looking for Used Tools and Equipment
    By wmont65 in forum Horological Tools
    Last Post: 11-01-2008, 12:52 AM
  2. Sources for used tools and supplies
    By Chris Gregory in forum Horological Tools
    Last Post: 10-31-2006, 09:16 PM
  3. Replies: 5
    Last Post: 06-01-2004, 04:09 AM
  4. Balance and hair spring needed for elgin 2577889
    By usadude in forum American Pocket Watches
    Last Post: 09-14-2002, 04:15 PM
  5. Seth Thomas and Howard dials needed
    By Glenn Morrison in forum American Pocket Watches
    Last Post: 12-27-2000, 04:49 AM
