Goal: $300, Received: $275.00 (92%) Contribute Now
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
    Default Seeking Opinions on spring condition
    This comes out of a small visible escapement French clock. My initial feeling is that there's plenty of room left to just smooth and reshape the worn part of the hole. Of course I could also cut it off and re-hole it .... but I cant see where that would be much better. What are your opinions?
    Nov 2002
    39,822
    Default Re: Seeking Opinions on spring condition (By: shutterbug)
    I would re-hole it. Is there a part of it folded under the spring hole? If so, eventually the barrel hook won't properly catch the spring.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Default Re: Seeking Opinions on spring condition (By: harold bain)
    No, nothing folded under. I have 5/8" left from the end of the tear to the end of the spring. I think that's about all American springs have. I was thinking of just extending the original shape down to the bottom of the tear.
    Nov 2002
    39,822
    Where do you suppose the piece went? Perhaps a previous repairman just cut it off?
    Registered user. shimmystep's Avatar
    Mar 2012
    Cambridge, UK
    3,624
    I'd cut it off, anneal and re-hole it shuts.
    shimmystep.
  6. #6
    Dec 2011
    Brockville, On Canada
    5,678
    Is there something with the hook that should be smoothed or addressed to prevent or minimize future damage.?
    David
    David S
  7. #7
    I would cut off the spring & punch a new hole in fresh material. The pin may also have a deep groove worn into it.
    I wouldn't like those two thin rails that are on each side of the slot which was an oblong hole
    Just my two cents.
    At the end of the day it's in your capable hands.
    The man who knows how to make it work will always have a job, The man who knows why it makes it work will always be his boss. Website http://sailorsandsettlersantiques.com
  8. #8
    I guess someone has to be different. Looks to me like someone deliberately cut that narrow slot to keep it from jumping off the pin. I wouldn't do anything except perhaps smooth it up a bit and try to get the spring straight. Looks like a little cone ing going on here as well. I assume it has been working ok.
  9. #9
    Default Re: Seeking Opinions on spring condition (By: R. Croswell)
    Hmmm. I had assumed that it just dug a groove over time ... but the strike side does not show similar wear.
    I'll look at the hook and make sure it's not sharp. Maybe RC is right, and it was done deliberately. Strange. You would expect that kind of wear on the business end, but not on the barrel hook. I'm still pondering. Thanks for all the input!!
    BTW, there was no debris found in the barrel.
  10. #10
    Perhaps a previous repair was done to remove/file some cracking/splitting steel. There appears to be some file marks on the end of the spring. I think I would punch a new hole.
  11. #11
    Registered User wow's Avatar
    Jun 2008
    Pineville, La. (central La.)
    2,034
    Default Re: Seeking Opinions on spring condition (By: Time After Time)
    One consideration not mentioned so far is the annealed section of the spring. Some springs are softer at the outside end so they catch the barrel pin more easily. If you cut it at the hole and re-hole it, you may be into the harder section of the spring. You would need to anneal the spring so it would be less stiff and bend as it did originally. This may not be a factor in your case. I probably would clean it up and leave it as is.
    Will Walker (WOW)
  12. #12
    I would guess that this hole has broken out several times. I never liked the idea of a "D" shaped hole anyway. This shape puts a lot of bending force at the center, and corners, of the flat side of the D. Much better to have a well centered pear shaped hole. You will have far fewer tearouts.
  13. #13
    Default Re: Seeking Opinions on spring condition (By: Willie X)
    With the large part toward the hook?
  14. #14
    I don't think it matters. It's no more work to cut, anneal, and re-hole than it is to clean it up with a file. And vice versa.
    Is what I think.
  15. #15
    Registered user.
    Dec 2011
    Eastern Cape SA
    209
    Blog Entries
    Default Re: Seeking Opinions on spring condition (By: bangster)
    It seems to me that the hole was originally too large for the hook. I would aneal the spring and drill a new smaller hole a bit larger than the hook and hand file the shape accordingly.
  1. Seeking opinions on how far to restore my tower clock
    By Stotman in forum Tower, Monumental, and Street Clocks of the World
    Last Post: 12-03-2014, 01:52 AM
  2. Seeking another opinion on this movement. What manufacture is it? T.I.A.
    By A.F.W. in forum European & Other Pocket Watches
    Last Post: 05-10-2009, 09:14 PM
  3. Your opinion on the necessity of cleaning a movement.
    By Tom Kloss in forum Clock Repair
    Last Post: 08-29-2006, 02:41 AM
  4. Opinions on Breitling
    By RonC in forum Wrist Watches
    Last Post: 09-27-2005, 01:01 AM
  5. Union Glashuette: Any opinions on this watch?
    Last Post: 01-27-2004, 10:57 AM
