Goal: $300, Received: $275.00 (92%) Contribute Now
Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
  1. #31
    Registered User gmorse's Avatar
    Jan 2011
    7,038
    Blog Entries
    Default Re: Lancashire watch co front set arbor and wind pw? (By: Tom McIntyre)
    Hi Tom,
    If you mean the fusee arbor itself, then extending that to enable front winding is non-trivial, and where a watch has been converted or re-cased, necessitating the arbor square to be at the other end, the whole fusee was typically replaced. Extracting the arbor from a fusee cone is practically impossible without destroying it. Fusees with a square at both ends were available from materials houses, the unwanted end was simply cut back to form a normal pivot. Better as Ray says, to start with a front-winding verge in the first place.
    "Ut tensio, sic vis" - Robert Hooke
  2. #32
    Default Re: Lancashire watch co front set arbor and wind pw? (By: gmorse)
    Thanks all sound advise
  3. #33
    Default Re: Lancashire watch co front set arbor and wind pw? (By: Omexa)
    Ray you are right
    The guy selling is nice but here in US getting working movements is either shipping and customs from Europe collecters.etc
    I have trouble moving alot but in New York City there is a corner a watchmaker told me about where many watches are sold and parts etc so maybe
    Thank you
    Im learning (thick but resonable head)
    Lol
    Rob
  4. #34
    Tom
    Thanks so
    Much!
  5. #35
    Default Re: Lancashire watch co front set arbor and wind pw? (By: novicetimekeeper)
    Im still not sure but Im not selling it so matters
    Robomam
    - - - Updated - - -
    Sorry learning
  6. #36
    Ray
    Only measurements I need would be distance between wind arbor and set
    Nut . The time will work anyway it is tightened into the clips(3) and place for a fourth
    Oh and double check on the 43.3mm movement front plate size
    Does that sound correct since there is no hinge ?
    Robo
  7. #37
    Default Re: Lancashire watch co front set arbor and wind pw? (By: Roboman)
    Quote Originally Posted by Roboman View Post
    Robomam
    - - - Updated - - -
    Sorry learning
    If it isn't plastic then it is ivory, here that would not be a problem selling it as it is clearly old enough, but as you say well worth keeping anyway.
    Nick, lots to learn, late starter.
  8. #38
    Default Re: Lancashire watch co front set arbor and wind pw? (By: DaveyG)
    Hi Roboman, sounds OK, but the thickness of the movement will be different; you may have to make New holding Clips? Regards Ray
  1. Lancashire Watch Co/ Waltham Watch Co
    By Knownothing in forum European & Other Pocket Watches
    Last Post: 05-28-2013, 02:49 PM
  2. Lancashire watch co prescot pocket watch (2392)
    By master26 in forum European & Other Pocket Watches
    Last Post: 11-09-2012, 01:15 PM
  3. English Pocket Watch Lancashire Watch Co. watch pats needed
    By Dutto11 in forum Watch Repair
    Last Post: 02-01-2012, 04:23 PM
  4. Gold (?) pocket watch Lancashire Watch Co
    By bebuscom in forum European & Other Pocket Watches
    Last Post: 02-10-2010, 01:40 PM
  5. Lancashire Watch Co Prescot
    By Skelly in forum American Pocket Watches
    Last Post: 06-19-2006, 10:59 PM
