Results 16 to 21 of 21
    Registered User KurtinSA's Avatar
    Nov 2014
    San Antonio, TX
    1,556
    Default Re: Tiny Cuckoo Clock (By: shutterbug)
    No bur on the end of the arbor...I did file it a bit just to be sure. The only way this was going to work was to use a cutting broach in very small increments...cut, test fit, cut some more. Finally I was able to open it up enough to slip the hand into place. Attached is a picture of the back plate.
    It's up and running...will take a look at time regulation. If all is well, then I'll send back to my cousin.
    Kurt
    Default Re: Tiny Cuckoo Clock (By: KurtinSA)
    13,641
    Always do your rate adjustment at 1 day. the rate will
    change quite a bit over that time frame.
    Nov 2014
    San Antonio, TX
    1,556
    Default Re: Tiny Cuckoo Clock (By: Tinker Dwight)
    I agree Tinker. But I want to get it somewhat close, then let my cousin do the final adjustments when she puts it up.
    Kurt
    Nov 2012
    Denver, Colorado
    178
    How fun! I'd leave the minute hand off and make it a cuckostudenuhr.
    Confucius say: "Man own clock know time. Own two, never sure."
    Default Re: Tiny Cuckoo Clock (By: Willie X)
    I have 3 of these tiny cuckoos. I got a perfect novelty key from Timesaver. They probably have the pendulums too
  1. cuckoo clock parts
    By randy laham in forum Clocks General.
    Last Post: 05-08-2017, 11:28 AM
  2. Cuckoo Clock Squeak
    By kirklox in forum Clock Repair
    Last Post: 01-24-2014, 10:53 PM
  3. Cuckoo clock movement question
    By mckpaul in forum Clock Repair
    Last Post: 03-25-2012, 09:51 PM
  4. Cuckoo clock weight questions
    By eskmill in forum Clocks General.
    Last Post: 10-15-2005, 08:46 AM
  5. cuckoo clock large music box w/batt
    By randy laham in forum Clock Repair
    Last Post: 08-10-2005, 10:48 AM
