Goal: $300, Received: $275.00 (92%) Contribute Now
Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
  1. #31
    Default Re: unmarked banjo clock... (By: Andy Dervan)
    Hi Andy, some confusion reigns.........have we now made common usage of the term "presentation pediment" re PTP instruments and incorporated it into everyday usage?
    If so then my clock is a contemporary clock which I find hard to believe and it's age and attribution is unknown to me.
    I have the book and it may be a wee bit vague on this term.
    Thanks for your input,
    Bruce
    Es mejor morir de pie, que vivir de rodillas.....Emiliano Zapata Salazar
  2. #32
    Default Re: unmarked banjo clock... (By: novicetimekeeper)
    Quote Originally Posted by novicetimekeeper View Post
    I agree, just noticed oculus. On a longcase we call that a lenticle. Whenever I see oculus it makes me think of the Pantheon.
    One of those interesting bits of horological vocabulary.
    I've tended to use the term "lenticle", which is a small lens or lens shaped formation, to describe the small glazed window in the door of a tall case clock for viewing the pendulum.
    I've used the term "oculus" to describe the open space in the eglomise panel of a clock for viewing the pendulum.
    I've seen the latter used this way in the literature and auction catalogs as well.
    Though Latin, it's all Greek to me ;>)
    RM
  3. #33
    Hello Bruce,
    It is called "Lower Bracket or Bracket"; I have never heard the term either verbally or in writing "presentation pediment".
    I do not know what term "PTP" means.
    Your clock dates from 1840s, however it has been heavily modified:
    Glasses are much later reproductions - original glasses were black and gold
    Brass sidearms are incorrect - clock either had none or wood sidearms.
    Original finial was wood
    Weight was stamped Tifft
    These clocks were competing as lower cost options vs. Howard & Davis in Boston.
    I will attempt to take a photograph of a signed Tifft clock that I have..
    Andy Dervan
  4. #34
    Quote Originally Posted by Andy Dervan View Post
    someone used it for 'patent timepiece'
    i collect antique clocks because i get all that extra time...
  5. #35
    Default Re: unmarked banjo clock... (By: bruce linde)
    Two Bruce's, my clock is the crotch mahogany case.............................
  6. #36
    Default Re: unmarked banjo clock... (By: Bruce Barnes)
    Quote Originally Posted by Bruce Barnes View Post
    no... one Bruce and one bruce.
  7. #37
    better repro hands from timesavers...
  8. #38
    Registered User George Nelson's Avatar
    Oct 2007
    Tennessee
    872
    Bruce,
    Your clock looks super- really like the hands! Look at all we have learned from the original posting of your clock- THANKS!!!
    George
    Time is a great story teller... Irish Proverb
  9. #39
    Default Re: unmarked banjo clock... (By: George Nelson)
    I agree, the new hands have a much lighter look, a worthwhile change.
    Nick, lots to learn, late starter.
  10. #40
    thanks, guys... it doesn't show in that photo, but the repro hands (from timesavers) are blued... and from the right angles or with the right lighting are just gorgeous.
    cheap thrills! 8-)
    thanks again for the wise counsel.
  1. Unknown Banjo Clock
    By Kim St.Dennis Sr. in forum Clocks General.
    Last Post: 09-04-2012, 12:10 PM
  2. eagle statue on banjo clocks
    By purpledog in forum Clock Repair
    Last Post: 12-30-2005, 09:19 AM
  3. Need help dating an S.T. Banjo clock
    By Chris in forum Clocks General.
    Last Post: 02-06-2005, 08:14 AM
  4. Looking for "York" Sessions Banjo Clock
    By EscapeWheel in forum Clocks General.
    Last Post: 06-20-2003, 11:56 AM
  5. Ingraham Banjo Clock
    By Pete Riegel in forum Clocks General.
    Last Post: 01-26-2003, 07:24 PM
