Results 1 to 7 of 7
    Default Flakig Dial-Dusty-How To Clean?
    I I bought a clock that had no glass in bezel. It is flaking in areas and the dial is dirty/dusty. Any recommendations on how to clean it?
    Thanks
    It is dusty-curious how to clean or remove dirt.Thanks.
    Popeye-Love This Forum!!!
    Default Re: Flakig Dial-Dusty-How To Clean? (By: popeye)
    The choices are pretty much: to enjoy it like it is, or have it restored.
    Default Re: Flakig Dial-Dusty-How To Clean? (By: Willie X)
    You could try a very soft paint brush to remove some of the dirt, but if the dial is flaking some of that will come off too.
    Registered User klokwiz's Avatar
    Feb 2009
    Annapolis, MD
    1,006
    popeye,
    it depends, what is the dial made of? Since you said it has bezel with no glass it is likely a mantel type clock. Most have paper dials, others ceramic fired dials.
    first step would be to lightly brush dial with a soft horsehair brush, this will lift any loose dirt from dial regardless what type.. As was mentioned if the dial is coming apart you will lose some dial so be careful. Best thing is to go slow and keep an eye (popeye) on what is coming off.
    If the dial is paper the best approach is to brush off dirt. do not brush it in but brush to lift dirt off surface. There are commercial paper cleaners you can use but only after brushing.
    if your dial is ceramic, brush it first. then try a little water to clean any spots. taking care not to rub hard and to be sure that any print or numbering is not being removed. some dials have unfired ink numbering, very delicate.
    If your dial is silver colored it may be silvered and will be damaged by any abrasive or cleaner. bush it and only use water on any spots to see if they will lift. gently with a q-tip
    Joe
    Default Re: Flakig Dial-Dusty-How To Clean? (By: klokwiz)
    Maybe I misunderstood, but I thought the OP meant that the glass was missing, not that there never was glass in the bezel.
    But as I said, perhaps I misunderstood.
    Default Re: Flakig Dial-Dusty-How To Clean? (By: JTD)
    thanks all
    Feb 2009
    Annapolis, MD
    1,006
    popeye,
    what no feedback , no photos?? call me, sometime??
    Joe
  1. Mechanical Wristwatch How to clean 1957 Omega Seamaster Face/Dial?
    By SanJoseMichael in forum Watch Repair
    Last Post: 10-11-2008, 08:37 AM
  2. How To Clean 2 Old Metal Dials?
    By popeye in forum Clocks General.
    Last Post: 06-02-2008, 04:46 PM
  3. Burlingtons.How to clean a metal dial?
    By Randy Becker in forum American Pocket Watches
    Last Post: 09-02-2006, 12:40 PM
  4. how to clean dial
    By purpledog in forum Clock Case Restoration and Repair.
    Last Post: 01-07-2006, 04:45 PM
  5. W & H Dial => How to clean off the brass face
    By thebatteryman in forum Clock Repair
    Last Post: 06-20-2005, 10:29 PM
