    Default 12 Inch Dial-What Diameter Glass To Repalce?
    I do have the bezel and would like to know is there a standard sixe replacment or do I measure bezel? If so from just before the back of clips?
    Popeye-Love This Forum!!!
    Default Re: 12 Inch Dial-What Diameter Glass To Repalce? (By: popeye)
    Carefully measure the bezel opening in the North-South and East-West directions and try to come up with a glass about
    1/8" less than the opening. If you have a cast bezel use the the smaller of the two dimentions, for a thin sheet metal (flexable) bezel you can average the two measurements.
    Default Re: 12 Inch Dial-What Diameter Glass To Repalce? (By: Willie X)
    thanks!
    39,893
    You will also have to determine if the original glass was flat or convex.
  1. Large 12 inch Dial and Ladder Movement
    By JB in forum Clocks General.
    Last Post: 12-31-2010, 03:30 PM
  2. Oxidized dials : what to do ?
    By graybear in forum Watch Repair
    Last Post: 03-05-2009, 10:32 AM
  3. HELP TO I.D. WALL REG. 16 INCH DIAL TIME & STRIKE
    By qldinc in forum Clocks General.
    Last Post: 12-18-2007, 06:15 PM
  4. Who's decision was it for what dial and damaskeening was to be done.
    By Randy Becker in forum American Pocket Watches
    Last Post: 06-25-2006, 01:38 AM
  5. Dial scale of 0 to 300, what's that about?
    By mikeh in forum American Pocket Watches
    Last Post: 04-03-2003, 05:55 AM
