    Registered user. S1ider's Avatar
    May 2012
    Peterborough UK
    411
    Default Trifix mainsprings
    Can somebody confirm that Trifix mainsprings come pre-lubricated. According to Cousins they do. I have always brought my springs from them, but have always cleaned and lubricated before installing. If they come lubricated like Cousins say they do then it will be a bonus. I thought it was an inhibitor on them to prevent rust, but surely Cousins should know ? Shouldn't they ?
    Default Re: Trifix mainsprings (By: S1ider)
    They might lube them there, but typically the goop on the spring is just a rust inhibitor, and makes a poor lubricant.
    Registered user. shimmystep's Avatar
    Mar 2012
    Cambridge, UK
    3,645
    Default Re: Trifix mainsprings (By: shutterbug)
    Tri-fix springs from cousins, or from anyone, always need a clean and lube before installing. Not only do I think that what they are covered in is an inhibitor, the annealed ends of the springs are covered in carbon scale. This will only serve to crack and distribute in the spring and inhibit its intended action, i.e. it will inhibit the the coils sliding over each other.
    shimmystep.
    May 2012
    Peterborough UK
    411
    Default Re: Trifix mainsprings (By: shimmystep)
    Thanks guys. I will just continue as i was then.
    I have been using Trifix springs for the last 7 to 8 years which must amount to thousands by now, this what I currently do
    Remove scale from both ends use paper towel to clean off the rust inhibitor, grease then use Hermle barrel centre and my home made spring winder
Name:	Triffix Springs 150-002.JPG
ID:	350716   Click image for larger version.
Name:	Triffix Springs 150-003.JPG
ID:	350717   Click image for larger version.
Name:	Triffix Springs 150-005.JPG
ID:	350718   Click image for larger version.
Name:	Triffix Springs 150-006.JPG
ID:	350719   Click image for larger version.
Name:	Triffix Springs 150-008.JPG
    Stephen Benson - Clock website www.ajsbsa.co.uk There is no time, only clocks
    May 2012
    Peterborough UK
    411
    Default Re: Trifix mainsprings (By: AJSBSA)
    Thanks for the pics Stephen. Good info. Obviously you find that Horoglide works well. Do you keep topping it up or do you buy a new syringe full each time ? I have never used that before. Or is that not whats in it ?
    Quote Originally Posted by S1ider View Post
    Hi I have been using M&P mainspring grease for years with no problems, Horoglide is a new product from M&P which comes in its own syringe tube I am very happy with it but what ever you do, do not buy their Graphite grease it is truly awful to apply you will spend a huge amount of time cleaning up after using it.
    May 2012
    Peterborough UK
    411
    Thanks. I shall have a look at Horoglide.
  1. Trifix Clock Mainsprings
    By AJSBSA in forum Clock Repair
    Last Post: 04-06-2015, 11:31 AM
  2. American Pocket Watch Mainspring Letdown Point
    By Bidemhi in forum Watch Repair
    Last Post: 12-27-2006, 07:01 AM
  3. Replies: 12
    Last Post: 06-17-2005, 01:28 PM
  4. Mainspring lube
    By Don Havens in forum Clock Repair
    Last Post: 12-08-2004, 06:22 AM
  5. In need of a 19J Elgin BW Raymond 18 size mainspring Barrel
    By cmedsker in forum American Pocket Watches
    Last Post: 10-17-2001, 08:39 AM
