    Default Record W Co. movement in A.W.C. Co. Case
    Typical story, my great grandfather left me a couple of pocket watches.
    One I was able to determine is a 1916 American Waltham. The Cover has a slight bend in it and the cover hinge needs to be re soldered but other than that the case and the movement are in exceptional condition.
    The second one is proving more difficult to find information on.
    As shown in the photos it is engraved on the movement "Record W Co.", 4 Adjst, 100800, Swiss.
    The back of the case cover is engraved Empress w/ Crown trademark, A.W.C. Co., 3643912, Case made in Canada
    What I was able to find out about the movement was that is was most likely manufactured by Lancaster Watch Co. in Lancaster, Pennsylvania in or around 1886. This is the part that I am looking for help in confirming.
    The size should be 18s.
    Researching the American Watch Case Co. shows that they did have a canadian operation that began production around 1885 in Toronto, Ontario, so the timeframe for the movement 's production is at least plausible.
    The movement could probably use a thorough cleaning but it still runs like a top.
    Any help locating more information about this watch would be greatly appreciated.
ID:	350246Click image for larger version.
    Default Re: Record W Co. movement in A.W.C. Co. Case (By: nyx)
    If it says Swiss on the movement then that's exactly what it is.
    "Back in the day" the movement and case were separate purchases from separate manufacturers, so they need to be analysed in isolation.
    Nice case - 10-sided is a little unusual. You could consider temporarily switching in a standard-size movement to find out what size it is. I'd guess 12s or 16s.
    That looks like a penknife someone's attached to it at some point - this is quite a common thing to find.
    My guess a 12 Size case, movement not made by Lancaster, as topspin has said it is marked Swiss, and you have said it is the "Record W Co", so it is Swiss.
    Default Re: Record W Co. movement in A.W.C. Co. Case (By: Bila)
    As it is a Swiss movement, I'll move this to the European forum.
  1. Identification of movement in a Dennison Watch Company Case
    By Senezi in forum European & Other Pocket Watches
    Last Post: 09-30-2016, 03:50 AM
  2. Replies: 19
    Last Post: 02-21-2015, 04:43 AM
  3. IWC Movement in Demi Hunter Wrist Watch Case?
    By jacksilver in forum Wrist Watches
    Last Post: 06-14-2013, 08:47 PM
  4. Waltham Vanguard & Crescent St 21j movements in need of a good case
    By madlag in forum American Pocket Watches
    Last Post: 08-12-2012, 03:50 PM
  5. 6/0 Waltham movement in 10 or 12 size case
    By Scott Tipton in forum American Pocket Watches
    Last Post: 09-07-2004, 01:33 AM
