Goal: $300, Received: $20.00 (7%) Contribute Now
Page 1 of 2 12 LastLast
Results 1 to 15 of 26
    Registered user. Mikie T's Avatar
    Jun 2012
    Meridian, MS
    452
    Default Extra Large Elgin movement
    Hello everyone,I recently acquired this SIZE 37 watch / clock. I wasn't sure if I should post it in this forum but I thought maybe there would be more Elgin experts here than in the clock forum.
    AS I UNDERSTAND IT..... Elgin never REALLY got into the clock making business. I have seen MANY clocks that have the Elgin name attached to them but they were not made by Elgin. These were either made in Germany or Japan or elsewhere.
    BUT.....
    This is an actual Elgin movement that you can search the SN in Wayne's data base and it gives you....
    Year... 1926, Grade... 471, Size... 37, Jewels... 7, 8 day movement.
    I know that Elgin made some large movements that were used as wind-up car clocks. I have seen these and they have a L..O..N..G winding stem. But, this one has a short stem and a fancy dial. The octagon shaped bezel makes it look like it belongs in a clock case.
    This movement is a size 37 movement, which when translated into inches would be about 2 3/8".
    For comparison, an 18 size movement is about 1 13/16".
    SO....
    2 3/8" minus 1 13/16" gives a difference of only 9/16"...... Just over 1/2"..!!
    (that is not a whole lot...)
    So you see, a 37 size movement is not TWICE as big as an 18 size movement. There is really not that much difference in actual size.
    I guess you could fit it in your pocket...... MAYBE.
    Anyway, any of you Elgin guys have any idea of the history of this animal?
    Mike
ID:	349960   Click image for larger version.
ID:	349961   Click image for larger version.
    Elgin National Watch Company, Elgin, Illinois.... Founded 1864. Makers of Pocket Watches, Wrist Watches, Bomb Sights and Precision Instruments.
    Registered user.
    May 2014
    Melbourne, Australia
    26
    Default Re: Extra Large Elgin movement (By: Mikie T)
    yes, over size pocket watch movement with two main springs.
    these are out of Elgin's 8 day travel clocks, an adventure in its self if you start out in it
    if you do start collecting these, do your research, there are a lot from the 60's that look older than they are.
    Jun 2012
    Meridian, MS
    452
    Default Re: Extra Large Elgin movement (By: diveboy)
    Thanks diveboy....
    I can see your movement and winding stem are similar to mine. SO... it appears that someone has robbed this movement out of a folding travel clock stand?
    Do you have any idea how many of these Elgin travel clocks were made?
    I see on Wayne's data base that there was about 377,500 of the serial numbers allotted for the 471 movements. I know a lot of those went to car clocks.
    Mike
    These were also installed as car clocks.
    Tom
    Apr 2002
    20,158
    Blog Entries
    Default Re: Extra Large Elgin movement (By: Tom Huber)
    Mikie i answered your posted on Glyn,s web site.
  6. #6
    Jun 2012
    Meridian, MS
    452
    Default Re: Extra Large Elgin movement (By: Kevin W.)
    Quote Originally Posted by Kevin W. View Post
    Ah. you must be Veritas
    10-4
  7. #7
    Apr 2002
    20,158
    Blog Entries
    Yes i am Veritas, i work at Veritas Tools, so i used the name.
  8. #8
    Registered User musicguy's Avatar
    Jan 2017
    New York State
    844
    "In Roman mythology, Veritas, meaning truth, was
    the goddess of truth, a daughter of Saturn, and the mother of Virtus.
    It was believed that she hid in the bottom of a holy well
    because she was so elusive. Her image is shown as a young
    virgin dressed in white" google
    RE: the travel clock
    I guess you should build a little stand for it, as the crown is on the bottom.
    (it's not a side winder but a bottom winder)
    Rob
  9. #9
    Jun 2012
    Meridian, MS
    452
    Default Re: Extra Large Elgin movement (By: musicguy)
    Quote Originally Posted by musicguy View Post
    Rob
    Yep, not a bad idea. I wouldn't mind having a real Elgin stem winder sitting on my nightstand.
    Mike
  10. #10
    Registered user.
    May 2014
    26
    you wont sleep with its ticking....
    I'm not sure how many were made, its on my list of projects to build up a list of models.
  11. #11
    Quote Originally Posted by diveboy View Post
    I dunno - I sleep with 5 16s, and 2 18s watches ticking away on my nightstand. And they're usually drowned out by the sound of the tree frogs down by the creek!
  12. #12
    Registered user. geo.ulrich's Avatar
    Apr 2013
    Alton Il.
    103
    Default Re: Extra Large Elgin movement (By: GeneJockey)
    Are you saying the tree frogs snore
  13. #13
    Default Re: Extra Large Elgin movement (By: geo.ulrich)
    Quote Originally Posted by geo.ulrich View Post
    They're too busy trying to get... Er, um, I mean 'trying to fulfill their biological imperative'.
    If you catch my drift....
  14. #14
    Jun 2012
    Meridian, MS
    452
    I know one thing.... for such a small frog those little jokers sure can make a BIG noise!
    Mike
  15. #15
    Jan 2017
    New York State
    844
    We have in New York State spring peepers, they are small frogs
    and they are LOUD. In the spring when we have our windows open
    there are times when they are all in unison(trying to find a mate)
    and it's hard to sleep.
    Every once in a while I wind up 15-20 watches. I have them in
    a curio cabinet, and when you open the door they are like spring peepers. lol
    Rob
  1. Elgin movement
    By ozzy in forum American Pocket Watches
    Last Post: 01-22-2007, 02:14 PM
  2. Elgin Movement Serial Number?
    By mersus99 in forum Wrist Watches
    Last Post: 07-05-2006, 10:24 AM
  3. need help on a Elgin movement?
    By kc092755 in forum American Pocket Watches
    Last Post: 08-14-2005, 04:35 AM
  4. American Pocket Watch Elgin Movement needed
    By DavidEFahrenholz in forum Watch Repair
    Last Post: 06-07-2004, 03:23 AM
  5. looking for 18S Elgin movement
    By Harold Clitheroe in forum American Pocket Watches
    Last Post: 10-23-2000, 07:52 AM
