Goal: $300, Received: $20.00 (7%) Contribute Now
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    Default 1860's Fusee in 18KT CONVERTIBLE case , runs fine, would like input!
    I am posting this here because the moderator in the European forum suggested that the case may be American and I may find someone who could shed some light on this. Here is the original posting: OK,let me start off by saying that I know I probably paid too much but when I saw this 18KT CASE,I just had to have it! I don’t think the movement is anything too special, except that it seems to be n excellent/near mint condition and runs very well. But that case!To convert between OF and HC ---- what engineering and craftsmanship! Fiendishly complicated, since I had NO prior experience with this case type, it took me an hour of careful, thoughtful manipulations to access all the covers without damaging anything. Photo 1 is the OF configuration, photos 2 & 3 the HC configuration. It measures 56mm and weighs 156 grams. So,I would like to ask a few things: 1) do any of you have a watch with a convertible case and if so would you mind posting a photo or two?,and 2) any general info on the movement or case would be appreciated(from some of the info I have read, the 25 Church St address would date this movement to an earlier time (pre 1830)than the case (1868)and yet the serial numbers match on both??) I have also posted this in "What's my watch worth forum for anyone interested. Thanks for any input in advance!
ID:	349951   Click image for larger version.
ID:	349952   Click image for larger version.
ID:	349953   Click image for larger version.
ID:	349954   Click image for larger version.
ID:	349956   Click image for larger version.
ID:	349957   Click image for larger version.
    Last edited by Dave Coatsworth; 07-12-2017 at 08:36 PM. Reason: Remove jumbo photos
    Technical Admin Tom McIntyre's Avatar
    Aug 2000
    Boston. MA USA
    19,471
    Blog Entries
    10
    Default Re: 1860's Fusee in 18KT CONVERTIBLE case , runs fine, would like input! (By: docbooks)
    As I mentioned in the value discussion, the "magic" is that the pendant moves with respect to the dial when the case is reconfigured.
    I think I recall that Clint had one of these at one time with a nice Howard movement in it, but that was a long time ago and my memories may be a bit scrambled.
    Tom McIntyre Click me.
    If you don't learn to laugh at trouble,
    you won't have anything to laugh at when you're old.
    Will Rogers
    Josh Johnson turned out some of Liverpool's finest movements. Regards Ray
    Registered user. Paul Raposo's Avatar
    Nov 2005
    Cambridge, ON Canada
    706
    Default Re: 1860's Fusee in 18KT CONVERTIBLE case , runs fine, would like input! (By: Omexa)
    Good Lord that's beautiful! Thank you for sharing these pics docbooks.
    Registered User musicguy's Avatar
    Jan 2017
    New York State
    844
    Default Re: 1860's Fusee in 18KT CONVERTIBLE case , runs fine, would like input! (By: Paul Raposo)
    Quote Originally Posted by Paul Raposo View Post
    yes I agree, thanks for sharing the photos of your beautiful watch.
    Rob
  6. #6
    Default Re: 1860's Fusee in 18KT CONVERTIBLE case , runs fine, would like input! (By: musicguy)
    Quote Originally Posted by musicguy View Post
    Rob
    - - - Updated - - -
    Thanks for the input Ray....I will be spending some time researching him!
    Quote Originally Posted by Omexa View Post
  7. #7
    Default Re: 1860's Fusee in 18KT CONVERTIBLE case , runs fine, would like input! (By: Tom McIntyre)
    And also the "Magic" is that some one could engineer and build this 150 years ago!
    Quote Originally Posted by Tom McIntyre View Post
    - - - Updated - - -
    Rob
  8. #8
    Nov 2005
    706
    Quote Originally Posted by docbooks View Post
    Without computer controlled machines or CAD!
  9. #9
    Or electricity!
  10. #10
    Jan 2017
    New York State
    844
    Someone should merge this thread and the other of the same topic.
    Rob
  11. #11
    Rob,
    docbooks posted in both the American and European forums for a good reason (English movement, possibly American case). Merging them back together would defeat that.
  12. #12
    Let me preface this by reiterating that I still have not become completely familiar with manipulating this watch! So, I included a video to show the conversion process as well as accessing the movement for anyone who is interested. https://youtu.be/-sZs3AbB6xE. But, be kind ---- "No watches were harmed in the making of this video"
  13. #13
    Registered User Clint Geller's Avatar
    Jul 2002
    Pittsburgh, PA
    916
    I have owned two American keywind watches, both Howards, with 18K reversible cases that used mechanisms patented by Baldwin. These were respectively a very early Model 1858 Type C, (Series I) Howard (movement and case with matching serial # 132!), and a first run nickel third series (Model 1862), SN # 21,572, with Mershon's regulator. I have also seen Waltham Model 1857 and 1859 Model movements in Baldwin reversible cases. I've also seen a second series Howard (Model 1858 Type E) in a silver Baldwin reversible case. However, the case in this thread does not seem to be of the same design, as it is a swing-out. The Baldwin mechanism has a ring holding the movement, which rotates on an axis oriented at a 45 degree angle (from 1:30 to 7:30) with the line made by the pendant and the back hinge. Thus, by rotating the ring by 180 degrees about its axis, one converts the watch from the hunting configuration to the open face case configuration. I'll post some pictures of the Baldwin watches later. (One of them is pictured on covers of my book.)
    Clint Geller, FNAWCC, # 84,947
  14. #14
    I am interested to view your photos and see how they differ with this one---- from your description, it sounds that the cases you describe would be a less confusing way to reverse the movement----thanks!
    Quote Originally Posted by Clint Geller View Post
  15. #15
    Jul 2002
    Pittsburgh, PA
    916
    I remembered that pictures of the two gold Baldwin reversible case Howard keywind watches I mentioned previously are available at the link below. Both of these watches were exhibited at the 2002 NAWCC National Seminar: "Boston, Cradle of Industrial Watchmaking," in Boxborough, MA, which I chaired. Click on the links therein to "S# 132" and to "nickel finish."
    https://web.archive.org/web/20160305.../howardcat.htm
  1. 1860's Fusee in 18KT CONVERTIBLE case , runs fine, would like input!
    By docbooks in forum European & Other Pocket Watches
    Last Post: 08-17-2017, 10:53 AM
  2. A. Rossel minute repeating and cased pocket watch in 18kt Help
    By miaggi2 in forum European & Other Pocket Watches
    Last Post: 10-27-2015, 03:16 PM
  3. Cronómetro supremo in a "convertible" fogel case
    By jjea in forum American Pocket Watches
    Last Post: 11-29-2014, 06:45 PM
  4. small numbers in Pocket Watch cases
    By VisionAirey in forum American Pocket Watches
    Last Post: 01-18-2007, 09:27 PM
