Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
  1. #16
    Registered user. kinsler33's Avatar
    Aug 2014
    Lancaster, Ohio, USA
    444
    Default Re: Yellow cast brass for restoring movements (By: MartinM)
    I've read about 'cast plate' cuckoo clocks on this forum, but I've never seen one. If those plates were actually cast and not rolled or hammered afterward, wouldn't some investigation into whatever technique they used be helpful? The thought of hammering sheet brass out of a cast slug would have me casting (sic) about for some alternative method.
    M Kinsler
    512 East Mulberry Street; Lancaster, Ohio USA 740-503-1973; kinsler33@gmail.com
    http://www.lancastereaglegazette.com/search/kinsler/
  2. #17
    Default Re: Yellow cast brass for restoring movements (By: kinsler33)
    They are cast as a flat sheet but thicker than the final requirement as casting very thin sheet sections is likely to lead to some gaps. You do see some faults in dial sheets, they are acceptable if under the chapter ring.
    Longcase dial plates from the North of England often had a sort of cartwheel spoked look under the chapter ring to save brass. Although these are called cutouts they were usually there when cast.
    Nick, lots to learn, late starter.
  1. Replies: 3
    Last Post: 01-02-2015, 06:17 PM
  2. Foundry for casting brass replica clock parts?
    By Jeffrey Konicek in forum Clock Repair
    Last Post: 09-12-2013, 03:04 PM
  3. Question concerning unusual cast brass cuckoo movement
    By cuckoocafe in forum Clocks General.
    Last Post: 03-05-2011, 09:31 PM
  4. cast brass cuckoo movement goes out of sink
    By bob n in forum Clock Repair
    Last Post: 06-04-2006, 07:14 AM
  5. oiling cast brass German cuckoo movements
    By Jeff56 in forum Clock Repair
    Last Post: 03-23-2004, 03:26 AM
