Goal: $300, Received: $80.00 (27%) Contribute Now
Results 1 to 2 of 2
    Default Wittnauer g11 kas 5506 17 jewels
    Hello
    Can anyone give me info on this watch ?
    face of watch says "wittnauer geneve ....automatic.
    stainless steel back.....screw on type
    numbers under back plate, and on watch mechanism...
    ......G11 KAS SWISS 5506 17 JEWELS ...
    Any info on this is greatly appreciated.
    also......can someone explain what "17 Jewels" means.?
    Thank you
    I also want to add......
    I removed the back with a small piece of inner tube.....(from a car tire).....
    grip is everything....no way could I unscrew the back with bare fingers.... ... small piece of rubber, and it unscrewed with ease!
    Default Re: Wittnauer g11 kas 5506 17 jewels
    Quote Originally Posted by JROCK8 View Post
    Hello
    Thank you
    Are you sure that is G11 and not C11, I think you have a C11KAS movement, auto (self-winding), probably made somewhere around the 1960's, a picture of the movement workings would be more beneficial. The 17 jewels are regarding the jewel bearings for the pivots on the train, balance wheels and the entry/exit jewels on the pallet fork, also the 5506 number would likely refer to the case style.
  1. womens wittnauer 17 jewel 10 kgf white gold
    By mandir in forum Wrist Watches
    Last Post: 08-05-2011, 01:35 PM
  2. Replies: 5
    Last Post: 07-11-2009, 12:20 AM
  3. Seth Thomas Model 5 17 Jewel
    By GD1 in forum American Pocket Watches
    Last Post: 08-03-2006, 04:02 AM
  4. Wittnauer 17 Jewel 73 Revue
    By whargis in forum Watch Repair
    Last Post: 07-06-2006, 03:50 PM
  5. GrandDads Pocket Watch - A.W.W. 17 Jewels, serial 22446593
    By Steven Mercer in forum American Pocket Watches
    Last Post: 01-25-2004, 03:32 PM
