Results 1 to 6 of 6
    Default INSA Table Clock Stops if Sitting 90 Degrees Upright: Otherwise Runs Fine
    Please help me with this table clock issue. Made in Yugoslavia, Brand: Insa. Alarm and winding keys work fine. Keeps time (needs some adjustment but can be done). Only thing that kills the charm- if the clock stands upright (90 degrees) the seconds dial stops and so is the clock. It runs ok from lying flat up to a 75-80 degrees upright position. Once it hits 90 degrees upright position, clock stops. It is cosmetically in beautiful condition. What could be the reason? Is it fixable by a person who has no clock mechanism knowledge? Or does not worth the time? Please help
ID:	347105   Click image for larger version.
ID:	347106   Click image for larger version.
    Registered user.
    Oct 2010
    13,335
    Default Re: INSA Table Clock Stops if Sitting 90 Degrees Upright: Otherwise Runs Fine (By: spiderman6)
    The most common problem is dirty, or warn balance wheel pivots and bushings.
    Default Re: INSA Table Clock Stops if Sitting 90 Degrees Upright: Otherwise Runs Fine (By: Tinker Dwight)
    I have moved this thread to the clock repair forum where I think it might do better.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
    Default Re: INSA Table Clock Stops if Sitting 90 Degrees Upright: Otherwise Runs Fine (By: Steven Thornberry)
    Tinker is correct. It was recently suggested that rotating the cups to a different position might help, but only if the balance wheel points are in good shape. If we could see what you have for a balance in that one it would help.
    Default Re: INSA Table Clock Stops if Sitting 90 Degrees Upright: Otherwise Runs Fine (By: shutterbug)
    should i remove the back to tale pic? or i just leave it at 80 degrees? i guess i have no expertise to fix the identified problem.
    Quote Originally Posted by shutterbug View Post
  6. #6
    Yes, remove the back and post a pic of the balance wheel (the one that oscillates back and forth)
  1. Replies: 3
    Last Post: 12-13-2013, 10:53 PM
  2. Clock stops running if strike weight not wound
    By rondele in forum Clock Repair
    Last Post: 04-05-2013, 09:42 AM
  3. Grandfather clock stopping
    By Steve G in forum Clock Repair
    Last Post: 01-17-2006, 01:36 PM
  4. Clock Stops at 1:10???
    By erngrover in forum Clock Repair
    Last Post: 06-01-2005, 12:00 PM
  5. Small clock runs when turned 90 degrees
    By joeZy in forum Clock Repair
    Last Post: 04-18-2003, 01:40 AM
