Thread: What is it?
    Default What is it?
    Hi, there are a lot of smart people who contribute to this forum; I was thinking of using these (I have 2 of them) Plastic containers for Electroplating Cases and small Watch Parts. What were they used for originally? Regards Ray Click image for larger version.
ID:	346954Click image for larger version.
    Registered user. LloydB's Avatar
    Feb 2006
    La Crosse, Wisconsin's West Coast
    1,468
    Default Re: What is it? (By: Omexa)
    Possibly for producing or
    demonstrating an electric arc?
    The top device would allow
    precise adjustment of the
    distance between the spherical
    ends.
    Feb 2006
    1,468
    Default Re: What is it? (By: LloydB)
    Another (possibly better?) guess:
    an apparatus for measuring high-
    voltage DC, by the length of the
    spark produced.
    Hi LloydB, it is a water tight container when upright; I wonder what sort of liquid was in it? Regards Ray
    19,070
    Maybe measuring the breakdown voltage of an inert gas. Would not want to put methane in it, but it might be OK if you knew there was no oxygen mixed in.
    Feb 2006
    1,468
    Thanks LloydB, I don't think I will be using it for the intended purpose; it sounds pretty lethal. Maybe not depends on the Amps. Regards Ray
    If the containers are liquid proof my guess is they are used to test the dielectric strength of transformer oils.
    I've used a similar bit of kit to measure the voltage from a Van de Graaf generator but that was airgap, no tank involved. I think in this case the voltage is known but they are testing the dielectric strength.
    408
    Default Re: What is it? (By: novicetimekeeper)
    Quote Originally Posted by novicetimekeeper View Post
    Assuming that the tanks are plastic, originally clear, their brownish color sure looks like they've seen transformer oil. High voltage engineering uses lots of spark gaps for one thing or another. They're notoriously inaccurate as measuring devices and untrustworthy as safety devices (that is, to allow currents to bypass vulnerable equipment), but in many cases they're the best alternative we've got.
    It's not clear how these would be of use in electroplating.
    http://www.lancastereaglegazette.com/search/kinsler/
    Hi M Kinsler, I was just going to use the container. I have a variable Voltage Power Supply. I just was curious what they were used for originally. Regards Ray
  1. What is it and how do I clean it?
    By Cathy in Hawaii in forum Clock Case Restoration and Repair.
    Last Post: 01-17-2007, 07:12 PM
  2. URGOS LOGO/TRADEMARK? WHAT IS IT?!
    By Christopher Isaac in forum Clocks General.
    Last Post: 12-01-2006, 01:52 AM
  3. "Inviso" - What is it?
    By Dave Coatsworth in forum Wrist Watches
    Last Post: 01-26-2006, 10:14 AM
  4. A question on an Omega, "What is it?"
    By Royboy in forum Wrist Watches
    Last Post: 09-14-2005, 07:29 PM
  5. What is it?
    By Brian C. in forum Horological Tools
    Last Post: 02-21-2005, 07:32 PM
