Goal: $300, Received: $115.00 (38%) Contribute Now
Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Default Re: Waltham Larger Dial Ship's Marine CLock (By: ShawnHVoils)
    Ralph,
    Thank you, Jim’s site has a wealth of information doesn’t it?
    Doug,
    You’re right of course; I was referring only to the major gauge manufacturers.
    I looked for pictures of Havard and Boston marine clocks I once had but I can’t find them. I think they may have had screw on bezels as well.
    D~
  2. #17
    Hello Shawn,
    You have to be an NAWCC member and can access it from the website.
    My 10 inch nickel brass case is hinged bezel.
    1899 Waltham catalog mentions the initial order by Star Brass and my clock is probably one of them.
    Andy Dervan
  3. #18
    Registered user.
    Nov 2012
    Denver, Colorado
    171
    Second hand seems too small to be useful.
    Is it the escape wheel?
    Confucius say: "Man own clock know time. Own two, never sure."
  4. #19
    Default Re: Waltham Larger Dial Ship's Marine CLock (By: Robert Gift)
    Robert, I honestly don't know for sure but I don't think so.
  5. #20
    Registered user.
    Oct 2010
    13,355
    Quote Originally Posted by Robert Gift View Post
    On a balance wheel it would be the next wheel back from
    the escapement. The escapement turns too fast.
  6. #21
    Default Re: Waltham Larger Dial Ship's Marine CLock (By: Tinker Dwight)
    I have a 37 size car clock,
    It is interesting to consider whether something like this was once used to place into ships clocks or the like...
    David.
ID:	347236   Click image for larger version.
Name:	Waltham 23726926 8 Day Car clock.JPG
  7. #22
    Default Re: Waltham Larger Dial Ship's Marine CLock (By: Douglas Romero)
    Doug, Waltham Marine clock came today and it is indeed a screw bezel, very heavy clock. Also, Andy was right on with the serial number which is 50,250. The case is twelve inches in front and slightly larger in the back. The dial is ten inches and the escapement runs across the top of the round movement plates. I was also pleased that the clock started running in less than one turn of the key. Thanks again for all the info and nice pictures, Shawn
  8. #23
    Hello Shawn,
    I would like to see movement photograph. I suspect movement looks similar to one used in Waltham Willard banjo clock. Double circular plates with 11 jewels and escapement mounted on top between the plates. See two attached images.
    Andy Dervan
Name:	lever escapement.jpg
ID:	348400   Click image for larger version.
Name:	lever escapement sideview.jpg
  9. #24
    Default Re: Waltham Larger Dial Ship's Marine CLock (By: Andy Dervan)
    Andy, I will try to take it apart again in the next few days. Yes, from the one glance I took, they are very similar, Shawn
  1. Help removing dial from ship's bell clock
    By Gerald C in forum Clock Repair
    Last Post: 02-19-2017, 12:27 AM
  2. Waltham dual dial clock
    By deloid in forum Your Newest Clock Acquisition
    Last Post: 10-23-2012, 05:45 PM
  3. Schatz ship's bell clock
    By mrb in forum Clocks General.
    Last Post: 12-31-2005, 06:40 AM
  4. Seth Thomas Merrimac Ship's Bell Clock
    By eskmill in forum Clocks General.
    Last Post: 04-29-2005, 02:31 PM
  5. Waltham WI Dial
    By Steve Beck in forum American Pocket Watches
    Last Post: 11-11-2002, 04:08 AM
