    Default this is a pocket chronometer?
    Hi everyone!
    Recently i bought an english silver pocket watch, George Priest, Norwich, serial 3937. This watch has also chronometer balance, but if i see good, it does not a chronometer escapement?
    This escapement is completely unknown to me. I upload some photos, maybe someone met with a similar one. Please help me, to identify this escapement.
    Best regards! Peter from Hungary
ID:	346163   Click image for larger version.
ID:	346164   Click image for larger version.
ID:	346165   Click image for larger version.
ID:	346166   Click image for larger version.
ID:	346168   Click image for larger version.
ID:	346169   Click image for larger version.
    Default Re: this is a pocket chronometer? (By: sternerp)
    Hi Peter, is it a variation of the Savage 2 Pin Escapement? Others will know? I like it very much. Regards Ray
    19,070
    Default Re: this is a pocket chronometer? (By: Omexa)
    At first glance it looks like a wide jewel Savage, but the key element that is missing is the impulse notch on the table. It has a passing crescent, so there is no impulse from a pin on the lever. A good closeup of impulse end of the lever would make it more clear. Here are some images from my collection. The drawing is the copyright property of David Penney and is used with permission.
ID:	346174Click image for larger version.
ID:	346175Click image for larger version.
    6,845
    Hi Peter,
    As Tom has said, this isn't a Savage, but a variation on the two-pin English lever, albeit a rather superior one, with a single wide trapezoidal jewel and a passing crescent. The action is exactly the same as a normal English lever. The lever itself shouldn't look particularly different, it just has a wider fork. The thing that is unusual is the use of a chronometer-type balance of the Earnshaw pattern, something that's not often seen in a lever pocket watch.
    It's certain that it wasn't made in Norwich, and there may be some frame-maker's marks on the pillar plate under the dial. Something to look for when you come to dismantle it.
    Peter - I have added this chronometer to the list I have been maintaining for non standard English levers. You will find a copy here
    http://mb.nawcc.org/showthread.php?1...=1#post1107939
    I have added it to the section 'Standard Lever Escapement with Dovetail Jewel (Dovetail Escapement) - for each entry there is a link to where the examples are listed.
    John
    Default Re: this is a pocket chronometer? (By: gmorse)
    Thanks very much everyone for the responses!
  1. 1893 WM Russell pocket watch need to know what kind of movement this is.
    By Texasnorton in forum European & Other Pocket Watches
    Last Post: 11-30-2013, 04:23 PM
  2. J.F. Bautte pocket watch or is it?? This is driving me nuts, help me sleep again!
    By gimpycanuck in forum European & Other Pocket Watches
    Last Post: 03-18-2013, 08:42 AM
  3. Please identify this pocket chronometer
    By BRIANWHALEY in forum European & Other Pocket Watches
    Last Post: 02-28-2011, 09:23 AM
  4. Replies: 6
    Last Post: 09-07-2006, 08:53 AM
  5. New Wrist Watch board. Is this now the Pocket watch board?
    By Ray Fanchamps in forum American Pocket Watches
    Last Post: 02-16-2001, 04:11 PM
