NOTICE Notice: This is an old thread. The last post was 3826 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 8 of 8
    Default Ithaca Calendar Set-up
    Where can I obtain technical information on the proper set up of the Ithaca Calendar clock mechanism?
    Default Ithaca Calendar Set-up (By: rwfischer)
    Nov 2002
    39,095
    Hi, RW. try Joel Warren at
    http://www.ithacacalendarclocks.com
    His home phone # 607-387-7104
    Harold
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    What did you need to know.
    Mike
    Ithaca Calendar Clock Co.,Inc.
    Hi Mike-
    I need to know how to set up the proper day, date, month, and year on my office calendar #4 made by Welch in1885.
    Ray Fischer, rwfischer3@aol.com
  6. #6
    Are you talking about an Ithaca Office #4 with a ENWelch movement-but an Ithaca Calendar movement?
  7. #7
    You can try this too:
    http://www.horology.com/htr-itha.html
    BOB
  8. #8
    Registered User lamarw's Avatar
    Jan 2002
    Lake Martin, Alabama
    1,643
    Blog Entries
    I have conducted a Forum search and found this thread. I have also read through Mr Losch's excelent article "On Setting and Adjusting Ithaca Calendar Clock Movements".
    I seem to have a different problem from the above reference material. The clock is an Ithaca Round Top Rosewood No. 5. (Picture of clock is on pg. 137 or Ly's "Calendar Clocks' and the movment & calendar mechanism are as shown on pg. 138.) Clock runs well and the calendar mechanism trips properly for the day/date and month.
    The problem is the mechanism trips every 18 hours vs. 24 hours (cycle time).
    It is a Horton Calendar mechanism with the two rods connecting 1/2 way up the back to a single wire to the clock movement calendar lever.
    I have spent several frustrating hours attempting to adjust the cycle time with little success. Anyone know a repair solution or adjustment tips that will help with this predicament.
  1. Calendar clock set-up
    By canwatch in forum Clock Repair
    Last Post: 03-25-2012, 08:03 AM
  2. Seth Thomas Office Calendar #4 Set Up
    By Dulen in forum Clocks General.
    Last Post: 03-04-2006, 11:34 PM
  3. Seth Parlor Calendar #9 Up For Auction
    By Bob W. in forum Clocks General.
    Last Post: 01-20-2006, 08:43 PM
  4. strike set up
    By pamacm in forum Clock Repair
    Last Post: 04-28-2005, 04:43 AM
  5. Ithaca Calendar Clock
    By rgtrepp in forum Clock Repair
    Last Post: 06-01-2003, 02:53 PM
