Results 1 to 3 of 3
    Oct 2011
    Hudson, Quebec
    309
    Default Stupid Question about mainsprings
    Okay, this may seem nit picky , but I have a question about the rings that mainsprings are stored in. Specifically, the white alloy springs. They all are silver colour on one side, but on the other side they can be silver, yellow, red, blue...any reason for this? Does it go to strength? I ask because i have a few Elgin 817s in white alloy, but I am not sure which strengths they are. I imagine the only way of checking the thickness is to remove them from the rings, then I am stuck with a bunch of uncoiled mainsprings! If I could define their strength based on the colour of the ring, it would be easier.
    Mar 2008
    Gothenburg
    2,813
    Default Re: Stupid Question about mainsprings (By: wilsonpaule)
    I have learned that the colored side should be towards you when you install the mainspring......
    It will be interesting to hear if there is a strength thing to consider as well.
    Default Re: Stupid Question about mainsprings (By: Skutt50)
    Quote Originally Posted by Skutt50 View Post
    In my experience the colour has nothing to do with the strength of the mainspring - it's more related to the brand of spring (Nivarox tends to be light blue, Generale Ressorts is dark blue, Schwab-Feller is red, etc.). Also, the side that the colour is on is not really related to the direction the mainspring goes in the barrel on the watches I work on - I have bought mainspring for a specific movement that the coloured side is random - buying the same springs from the same supplier for the same movement, sometimes it's up and sometimes down. I've also seen springs with colour on both sides of the ring.
    Cheers, Al
  1. Noob question about mainsprings
    By Lesfen in forum Clock Repair
    Last Post: 10-13-2014, 07:57 PM
  2. English Pocket Watch Question about a new mainspring
    By GRHunter in forum Watch Repair
    Last Post: 04-29-2012, 05:27 PM
  3. American Pocket Watch Two questions about mainspring replacement
    By wilsonpaule in forum Watch Repair
    Last Post: 12-07-2011, 04:21 PM
  4. Electrical Wristwatch Stupid Question on Mainsprings
    By Dale in forum Watch Repair
    Last Post: 08-03-2010, 10:24 PM
  5. Stupid questions about Omegas and redials
    By oldsprings in forum Wrist Watches
    Last Post: 09-19-2007, 08:00 PM
