Results 1 to 12 of 12
    Registered user. PJQL's Avatar
    Cornwall UK
    1,199
    Default Mainspring replacement cautionary tale....Bunn Special.
    Hi all,
    Just thought I'd share with you my latest and first experiences with replacing mainsprings
    without the use of a winder.
    I'd actually recently done the same thing successfully with a Waltham 1883, but this last one was a late WW1 era Bunn Special.
    The original spring had snapped in no less than three places! I sourced an alloy replacement via eBay from the US which arrived very quickly...except I got hit for a customs charge :-/
    Exposing and removing the barrel was an easy job...and so was removing the old damaged spring.
    After cleaning out the barrel, it just remained to insert the new mainspring, which was conveniently supplied preset in an aluminium transit ring. Hey presto into the barrel it went...perfectly :-)
    Until in my haste I realised I'd put it in the wrong way...GRRRRR!
    And that's a really serious lesson learned.....
    Fortunately I managed to remove it very very carefully without damaging or distorting it.
    Now to wind it back up again manually. I wore a pair of surgical gloves to do this, which made it easy to start with, but much more difficult to maintain it wound up enough to reinsert it into the transit ring. But persistence paid off and I managed to persuade it into the ring, and then on into the barrel it went.
    Reassembling the watch was a straightforward job, and now it runs perfectly...Phew.
    The morale of the story is of course to check that the spring is inserted the right way before committing yourself to inserting it into the barrel. I guess that I'm not the first...and won't be the last!
    Hope this was useful..in its' own small way!
    Regards
    Piers
    Attached Thumbnails Attached Thumbnails DSC_6895.jpg   DSC_6906.jpg   DSC_6907.jpg   DSC_6917.jpg   DSC_6919.jpg
    Piers Lawrence
    'In the end, time makes fools of us all...some more than others.'
    1,458
    Default Re: Mainspring replacement cautionary tale....Bunn Special. (By: PJQL)
    Indeed.
    Nov 2009
    Williamson County, Texas
    713
    Default Re: Mainspring replacement cautionary tale....Bunn Special. (By: roughbarked)
    Yeah, after putting the second mainspring in backwards several years ago, I started at least making a quick sketch of the center coil or which way the remains coiled if the spring was broken in the barrel. I nearly always take a picture of the spring in the barrel, but always always always make a sketch. Compulsive? Maaaaybe...
    Glen
    Default Re: Mainspring replacement cautionary tale....Bunn Special. (By: glenhead)
    Quote Originally Posted by glenhead View Post
    Yeah, after putting the second mainspring in backwards several years ago, I started at least making a quick sketch of the center coil...
    Glen
    I do the same thing as Glen does. Not compulsive, prudent. The fewer times you mess with mainsprings, the better. Live and learn.
    I wouldn't know. The CSOW course showed me how to remove mainsprings the proper and easy way. Also I bought some mainspring winders that make the job of installing them a cinch.
    Also, you're not wearing gloves in the second photo.
    Robert
    20,006
    Default Re: Mainspring replacement cautionary tale....Bunn Special. (By: MrRoundel)
    I have done the same before, it happens. Are these springs pre lubed, no need to clean before installing. You have a really nice watch.
    Cornwall UK
    1,199
    Default Re: Mainspring replacement cautionary tale....Bunn Special. (By: Kevin W.)
    Roughbarked/glenhead/MrRoundel....Thanks for the input everyone!
    Hi Kevin....Thanks!....And no I don't think they are, but I'd always clean the barrel out anyway now.. think I read that
    somewhere here on this forum.
    The alloy mainsprings are allegedly supposed to operate better...but because it's my first one, I can't really comment yet.
    Maybe someone else has experience with them.
    Piers
    Piers Lawrence
    If not using a drawing, I make a point of putting the arbor in the barrel, and making a strong mental note of which way the inner coil needs to run for the spring to work right. If I need to use a winder, I just put the winder down on the spring while I have it laid out in the correct direction...
    Dave.
    Nov 2009
    713
    Quote Originally Posted by PJQL View Post
    <snip>The alloy mainsprings are allegedly supposed to operate better...but because it's my first one, I can't really comment yet.
    Maybe someone else has experience with them. <snip>
    Piers, the thing about modern alloy mainsprings is that they're more predictable over the long term. The alloys they use are more resistant to becoming "set", where the spring loses its tendency to return to its original shape. That helps it provide a more even power across its usable length.
    Most modern mainspring alloys are also immune to corrosion. The old blued steel mainsprings frequently break because a sometimes-invisible bit of corrosion sets in and weakens the spring. Once a spring fails in one spot, it's pretty common for the shock to cause it to break in multiple places.
    I have several dozen new-old-stock blued steel mainsprings that I'll never use. None of the sachets has been opened and they've all been kept clean and dry, yet many of the springs have turned to powder. Of the ten or so I've tried, only one survived its first winding.
    Glen
    Cornwall UK
    1,199
    Thanks Glen,
    I guess that's progress. Old original mainsprings should be collectors items!
    Thanks for your input
    Piers
    Piers Lawrence
    Yep been there done that. Pictures and a sketch and a last second check to be sure.
    1,458
    P
    Glen
    I've never seen this. I am talking about mainsprings that have been in the shop stock for at least 80 years. I can't really be scientific about this other than to suggest that the sachets weren't intended to stay wrapped around the mainsprings that long.
  1. Illinois 163 Bunn Special Mainspring Arbor
    By ShawnHVoils in forum Watch Repair
    Last Post: 03-28-2017, 05:20 PM
  2. Illinois Mainspring Arbor For 163 Bunn Special
    Last Post: 02-19-2017, 12:45 PM
  3. Mainspring for 23 jewel bunn special sn 3731365
    By Jas in forum American Pocket Watches
    Last Post: 04-21-2014, 06:43 PM
  4. Dial replacement 24 J Illinois Bunn Special
    By James McDermaid in forum American Pocket Watches
    Last Post: 12-27-2013, 11:44 AM
  5. Needed - 16s, 21j Bunn Special Balance Cock Assembly
    By Ken Hags in forum American Pocket Watches
    Last Post: 09-15-2002, 12:05 PM
