Goal: $300, Received: $225.00 (75%) Contribute Now
Results 1 to 5 of 5
    May 2017
    Scottsdale, AZ
    Default Waltham Jewel Hole Sizing
    I'm new to the hobby of watch repair and still have a lot to learn. I need an upper balance hole jewel for a Model 1883 18s Waltham pocket watch. I tried to measure the pivot on the balance wheel and came up with 0.12 mm so I ordered a 0.13 mm jewel. However, the balance wheel seems to get jammed in the jewel hole when I try to put the balance wheel into the cock. Would that indicate a hole that is too small or have I screwed something else up?
    Thanks.
    May 2017
    Scottsdale, AZ
    Default Re: Waltham Jewel Hole Sizing (By: Jim Crawford)
    Sorry, I meant to post this in watch repair.
    Registered User richiec's Avatar
    Feb 2007
    Brick, Ocean, NJ
    5,432
    Blog Entries
    Possibly the jewel was not actually a 12 pivot, usually I get or try to get a selection of different sizes and hope for the best. Lacking a jewel hole gauge it is always a crapshoot when someone else sells you the jewel.
    Feb 2008
    Ticonderoga, NY
    192
    Quote Originally Posted by Jim Crawford View Post
    Thanks.
    Here are a couple of thoughts. While you may have measured a .12 pivot, the end of the pivot may have a slight bit of mushrooming at the end. If you carefully checked the pivot under magnification and it looked good then it is possible that your .13 hole jewel isn't really .13. It is always best to test fit the hole jewel to the pivot before installation. You should be able to see the pivot poke thru the hole and see a slight tilt of the jewel on the pivot. If you haven't damaged the hole jewel by jamming the pivot into it and it is just a tight fit you can dress the pivot and take just enough off to get the result you need. A lathe works best for this and I like to use Gesswein stones among other tools to remove material and harden the pivot.
    Roger
    May 2017
    Scottsdale, AZ
    Default Re: Waltham Jewel Hole Sizing (By: pocketsrforwatches)
    Thanks for your input. I'm learning slowly.
  1. Electrical Wristwatch Elgin Balance Jewel Hole Size
    By mauleg in forum Watch Repair
    Last Post: 06-17-2013, 01:14 AM
  2. Skeletonized 7 Jewel 18 size Waltham
    By bernie levine in forum American Pocket Watches
    Last Post: 08-26-2008, 11:49 AM
  3. a vintage Waltham 15-jewel pocketwatch, size 12 repair questoin
    By jimmy_boy_wi in forum American Pocket Watches
    Last Post: 04-18-2008, 07:15 PM
  4. Waltham model 57 size?
    By Kugler77 in forum American Pocket Watches
    Last Post: 11-20-2006, 05:47 AM
  5. Jewel hole size
    By Bob Baxter in forum American Pocket Watches
    Last Post: 01-05-2001, 07:03 PM
