Goal: $300, Received: $80.00 (27%) Contribute Now
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 47
Thread: Ibm 35-7
  1. #31
    Apr 2002
    20,107
    Blog Entries
    Default Re: Ibm 35-7 (By: Kevin W.)
    Hello again. Yesterday i went to losen the collar that is on the pendulum rod, when i went to tighten the screw it broke, so i managed to remove the screw but cant find a replacement yet. The bob is threaded to the rod. So am i correct that the screw has to be in place and tight so i can regulate it. I tried to turn the spoked nut and it wont move bob up or down.
  2. #32
    Nov 2002
    39,751
    It shouldn't make any difference at all, since the collar is at the top. If you had the pendulum apart, it will take a while to zone in on any accuracy
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  3. #33
    Apr 2002
    20,107
    Blog Entries
    I put a mark on the rod with a felt tip marker, i will try it again, it was running a bit fast.
    I am a bit confused, i just went to lower the bottom nut adjuster, bob would not come down, so tried to lower bob by turning it, and it lowered by turning the bob. I gave it about 3 turns.
  4. #34
    Nov 2002
    39,751
    You will get used to it, Kevin. The collar is to make sure it won't turn on its own while in use. The bob is threaded.
  5. #35
    Apr 2002
    20,107
    Blog Entries
    Default Re: Ibm 35-7 (By: harold bain)
    So that is right, you turn the bob and just use the adjuster to keep bob in place. Thanks. I will get a screw in the collar later. Would you know what thread the screw is.
  6. #36
    Nov 2002
    39,751
    No, but it should be reasonably common, and not metric.
  7. #37
    Apr 2002
    20,107
    Blog Entries
    Thanks Harold, i went to a fasteners store here and found its smaller than a no 4-40 tpi. maybe a hobby store might have it.
  8. #38
    Nov 2002
    39,751
    For regulating the clock, turning the spoke nut 1 turn is 1 second in 5 days, and turning it 1 spoke (1/4 turn of spoke nut) is 1 second in 20 days.
    Turning it 1 bob is 1 second per hour, and 1/4 bob is 6 seconds per day.
  9. #39
    Apr 2002
    20,107
    Blog Entries
    Thanks Harold, i am putting that info in my notes, so i will refer to them, i have the atomic clock near by.
    How often should i check time and regulate, maybe twice a week.
  10. #40
    Nov 2002
    39,751
    I only check mine about once a month.
  11. #41
    Apr 2002
    20,107
    Blog Entries
    Thanks Harold, its 20 seconds fast this morning. Once i get it closer i wont touch it for a month.
  12. #42
    Jan 2010
    358
    Hello Kevin,
    You'll never get exactly right. I run mine a bit on the fast side instead of the slow side. I can always get it right again by stopping the pendulum, waiting for the radio signal time to catch up and then start the pendulum up again. That's easier than trying to advance the hands on a slow clock to match radio time.
    Jim
  13. #43
    Apr 2002
    20,107
    Blog Entries
    Default Re: Ibm 35-7 (By: Jim Hartog)
    Thanks Jim, long as i get it close, i would be happy, i get good time keeping from my Seth Thomas no 2, hope i can get this on the IBM, 30 seconds or better in a month i hope.
  14. #44
    Jan 2007
    Sierra Madre, Calif.
    107
    Great clocks, the serial number label is missing from mine, so I don't know how old it is. Not sure what kind of wood either. has a reddish hue.
  15. #45
    Apr 2002
    20,107
    Blog Entries
    Default Re: Ibm 35-7 (By: Steve Murphy)
    Very nice collection Steve, Do you have a favourite one.
  1. IBM 35 slave synchronization
    By giorgio in forum Electric Horology
    Last Post: 06-16-2016, 09:54 PM
  2. IBM Master clock model 35 Parts?
    By Jeff in forum Clock Repair
    Last Post: 02-02-2011, 07:16 PM
  3. IBM 35 question
    By dumpsterdiver in forum Electric Horology
    Last Post: 09-30-2010, 01:03 PM
  4. IBM Model 35 etc Master Clock Worm Gear
    By eskmill in forum Electric Horology
    Last Post: 04-20-2006, 06:08 PM
  5. IBM Model 35 Mvt...plus?
    Last Post: 05-10-2003, 02:10 PM
