Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
Thread: Bott Clock
  1. #16
    Registered user.
    Oct 2010
    13,153
    Default Re: Bott Clock (By: ballistarius)
    I think I'd need to see a video before I could recommend any thing.
    Even then I may not be sure.
    These need beat setting just like any clock.
    You should try it without the pin wheel. The pallets should be even
    on either side.
  2. #17
    Moderator leeinv66's Avatar
    Mar 2005
    Launceston Tasmania
    7,623
    Blog Entries
    Default Re: Bott Clock (By: Tinker Dwight)
    Get rid of the spring you are using as a suspension. That will not work. It is suppose to have a thread suspension. A loop of cotton thread is all you need.
    Like this but neater:
    Cheers
    Peter R Lee: AKA (Pee-Tah) from Australia
  3. #18
    Registered user.
    May 2017
    Green Valley, Arizona
    I'd say that's the problem. If I slide the wheel with the pins back slightly it begins to work. Stops when the when moves forward again. Looks like I can bend the axle mount for the wheel slightly to move the pins back a little.
    Thanks.
  4. #19
    Registered user. ballistarius's Avatar
    Oct 2009
    Bilbao, Basque Country
    668
    Default Re: Bott Clock (By: ristomailer)
    Keep us informed!
    Aitor
    It's all an accident, an accident of hands. Mine, others, all without mind, from one extreme to another, but neither works nor will ever. Steiner
  5. #20
    Mar 2005
    Launceston Tasmania
    7,623
    Blog Entries
    Sorry, I missed the earlier post where you said you replaced the spring. There is some good information on the pallet flags in this thread: Click Here
    Cheers
  1. Cuckoo Clock Squeak
    By kirklox in forum Clock Repair
    Last Post: 01-24-2014, 10:53 PM
  2. New Haven Chiming clock
    By Richard Allin in forum Clock Repair
    Last Post: 07-11-2006, 10:04 AM
  3. Large depthing tool for Herchede clock
    By Kevin J.Hutchins in forum Clock Repair
    Last Post: 10-03-2005, 09:26 AM
  4. United Clock Co Model 975
    By Graham Mitchell in forum Electric Horology
    Last Post: 09-05-2005, 03:59 AM
  5. Grandfather Clock
    By apjarvis in forum Clock Repair
    Last Post: 11-21-2004, 06:12 AM
