Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
Thread: Hauck clock
  1. #16
    Registered user. Nicko's Avatar
    May 2007
    Australia
    174
    Default Re: Hauck clock (By: Tinker Dwight)
    OK then,
    The procedure is to adjust the drops and then the locks. How do I know when the drops are correct? What is the end result that am supposed to be looking for here. The guide says to raise or lower the pivot hole to increase or decrease the drop. What is the end point of the adjustment for drops i.e. what should I see when is it right.
    Cheers
  2. #17
    Registered user.
    Sep 2008
    Maryland
    781
    Default Re: Hauck clock (By: Nicko)
    Quote Originally Posted by Nicko View Post
    OK then,
    Cheers
    Hi Nicko, Since your clock acentric pivot has been changed, you can do some experiments with it. You can raise it up or down to see the net effect. Of course, make a mark before you do the experiments, so you can adjust it back to the original point before the adjustments. If you have a Schatz mini clock such as London Couch, you can easily do your experiments on it. This clock acentric pivot can be change easily. After you have done all the experiments, you will learn a lot and the experience willl remain in you for a long tine. Do not afraid to make mistakes, with patience, you will get it right eventurally.
    My experience is that as long as the EW teeth drop on the locking face 1mm or so (first moment landing point) from the transition point (corner between impulse face and locking face), the clock will work fine.
    You can also follow the guide table from RG 10th edition page 47. I did not follow it very well, but it may help you. I value more of experiments.
    Ming
  3. #18
    Registered user.
    Oct 2010
    13,149
    OK then,
    Cheers
    Unlike recoil escapements adjusting the drops by moving the depth
    adjust both drops at the same time and by about the same amount
    but in opposite directions.
    On a recoil it adjust mostly the exit drop onto the entrance pallet only
    and has little effect on the entrance drop.
    It is best to do this with little or no power in the spring. A split second
    of spinning the escapement wheel at full speed into loose pallets well
    bend the escapement wheel badly.
    Drop is the distance that a tooth falls onto the lock of the next pallet.
    These are so small you have to use a magnifier. There is what I call
    inside drop and outside drop. Inside drop is where the entrance
    pallet lets go of the escapement and it lands on the lock of the exit pallet.
    Outside drop is where the drop is off the exit pallet and the escapement tooth
    lands on the entrance pallet's lock.
    As you adjust this, it is possible that you'll see it miss the lock and land
    on the impulse face.
    This may mean that you need to move the pallet on the anchor down more
    to allow adjustment of the drops to land on lock surfaces.
    When adjusting and looking at one side, only adjust 1/2 the distance you think
    you need. This is because it is kind of like robbing Peter to pay Paul.
    As you open up the drop on one side, the drop on the other will reduce by the
    same amount.
    This is the nature of deadbeat escapements.
    Lowering the anchor opens up the inside drop while reducing the outside drop.
    Raising the anchor reduces the inside drop while increasing the outside drop.
    Once the drops are set, don't fiddle with it again. It should never need adjustment.
    Unlike most deadbeats, it is difficult to adjust the locks on these clocks because of
    the windup of the spring above the fork.
    On a regular deadbeat, you can set pallet depth by sliding the pallets in their
    mounts, on the anchor, statically. By this I mean you can move the anchor
    manually and watch where is lands on the next pallet. The only trick is to
    have them about the same amount out of the anchor to make beat setting easy.
    On these, if you set the lock this way, you will miss the lock surface and
    and land on the impulse, every time.
    The way I like to do it is first set the lever, exactly straight up. By this I
    mean exactly or at least exactly the same for each pallet.
    I do this by holding the lever up and putting a small dot one each plate at the
    edge with a sharpie pen. I want it so that if I site along the closer dot to the
    lever and the other dot, they are, all three, right in line. Use one eye only for this.
    When it is like this and there is light tension on the escapement wheel,
    one of the teeth of the escapement will, or should be, on the impulse face.
    It should have traveled about 1/3 the way across the impulse face.
    One then move the lever to let it escape to the other pallet.
    Carefully move the lever to exactly the same place by aligning the lever
    and the dots. Now look at where the tooth is on that pallet. It should be
    1/3 in its direction of travel as well. Adjust the pallets to achieve this
    1/3.
    The key to this is that the lever has to return to exactly the same place
    for each pallet. One of the other fellows tried to do it this way and failed
    because it wasn't exactly the same location. It was several degrees off.
    Check every tooth of the escapement. A bent tooth or short tooth will
    not be in the right, consistent, location.
    This will require fixing the escapement wheel ( I've found that if the escapement
    has been fiddled with, the escapement wheel is almost always damaged.
    Someone though they could safely adjust this under full wound power! ).
    Once you are satisfied with this lock adjustment, you can work on the fork
    height and beat adjustment.
    Remember, you need over swing but not so much that it flutters or fails
    to land on the lock surface. Total swing is not as important.
    So:
    1. Adjust for equal drops by adjusting the eccentric.
    2. Adjust the locks, compensating for the springs recoil of the anchor.
    3. Adjust the fork to have some over swing but no flutter.
    4. Adjust the beat for equal over swing in each direction.
  4. #19
    May 2007
    Australia
    174
    Hi Marylander & Tinker,
    Thanks for your replies. I have the escapement working at the moment. I will leave it going for tonight and have another look at it tomorrow. OK about the drops. I really don't know how you would reliably measure that. I could print a 360º circle and mount it behind the escape wheel as a guide.
    Its very difficult to see what's happening on the escape wheel. There are no peep holes on the rear plate. I have to turn the clock around and use a small mechanics mirror to see what's going at the entry pallets, trying to remember that, what I am looking at is a mirror image with the pallets reversed. As if it wasn't bad enough to have a clock where the escape wheel turns in a different direction from all the diagrams & texts that I have.
    The clock has been fiddled with. There is no escaping that. If I wanted to replace the escape wheel who would be able to supply or make one?
    Cheers.
  5. #20
    Registered user.
    Oct 2010
    13,149
    If there are no holes, the drops can be set by
    watching from the side and working the lever by hand.
    Right after the drop you can wiggle the escapement
    wheel back and forth.
    That should give you a good sense of the amount of drop.
  6. #21
    May 2007
    Australia
    174
    <alt><ctrl><del> for the clock. I've taken it apart again to bring the lever upright. There are some escapement wheel teeth that look a bit dodgy. I may be able to mount the wheel by the pivots in the lathe. I'll will see if I can make some runners that small. If I machined up a teeth cutter, I could use that to check tooth geometry. That might be an idea. I don't have a tooth cutter, but the tool will give me some idea.
    Thanks and cheers.
  7. #22
    Registered user.
    Oct 2010
    13,149
    You can use a piece modeling clay to make an impression.
    This will allow you to compare the spacing.
  8. #23
    May 2007
    Australia
    174
    I've used some plasticine to make an impression of the teeth, and then moved the wheel tooth by tooth until I see a tooth that throws all the other imprints off. This was partially successful
    I would like to make something a bit more rigid than plasticine. Using the measurements in the Repair Guide I sketched two teeth in a CAD program. From there I can get a CAD print of what I need to do.
    The first jpeg is the measurements that I could glean from the guide.
    I'll have Another try when I get the .JPG right
    Cheers
  9. #24
    Principal Administrator John Hubby's Avatar
    Sep 2000
    The Woodlands, TX
    10,924
    Nicko, this is a unique way to find misaligned teeth in an escape wheel. It should allow you to see all variances of tooth position.
    When you get the opportunity, it would be appreciated if you could post photos of your clock. There aren't very many with the 3-ball pendulum No. 26, would like to see the details so we can compare to the other clocks.
  1. Post Your Ph. Hauck 400 Day Clocks Here
    By Michael Davies in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 08-24-2016, 05:56 PM
  2. Hauck disc clock
    By Rachelmc in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 06-18-2014, 12:03 AM
  3. Serial No of my HAUCK clocks & movements
    By DieteR in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 07-28-2013, 10:05 AM
  4. "Umpire" 400-day clock with Hauck chronometer pendulum
    By antiekeradio in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 03-24-2010, 10:57 AM
  5. Post Your BHA, Becker, Grivolas, Hauck, Schlenker & Posner, and Würth Clocks Here
    By John Hubby in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 10-28-2009, 06:56 PM
