Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
  1. #16
    Default Re: Antique silver calendar pocket watch, Help with identification (By: gmorse)
    Hello
    I think that different countries and different case makers have/ had their own silver marks.
    Is it possible to identify the origin of a case eg country and case maker by this 875 silver mark, as it has a rather specific look about it?
    Please find image below.
    Regards Gary
  2. #17
    Default Re: Antique silver calendar pocket watch, Help with identification (By: gshep)
    I've never seen that specific banner design, but the mark is western European as determined by the use of a comma rather than a period for the decimal point. I have seen 87.5% marking on Swiss and French cases before, although this is reltively unusual - the more common Swiss purities are .800 and .935.
    If I had to guess, I would go for French, German or Swiss in that order of likelihood ... perhaps the unusual style of the "7" would be a further clue?
    Martin Rosen
  3. #18
    Default Re: Antique silver calendar pocket watch, Help with identification (By: MartyR)
    Hi Martin
    Were Henri Jacot -Burmann the inventors and patent holders to the calendar section of my watch, or just the patent holders?
    I also had a look today at European hallmarks and I am looking at France - Paris as possible makers of case.
    Thank you for your input, it was helpful.
    Regards Gary
  4. #19
    Hello
    When I first looked at the movement, it appeared that the bridge had been cut and joined
    But after taking a side on photo of the bridge, it has been machined and cut away, then gilded (not a bad job).
    Also can someone tell me from the photo how many jewels this movement has as it is not marked.
    photo of bridge below.
    Regards Gary
  5. #20
    Registered User gmorse's Avatar
    Jan 2011
    6,845
    Blog Entries
    Hi Gary,
    ...Also can someone tell me from the photo how many jewels this movement has as it is not marked....
    If all the jewels visible on the top plate are matched in the pillar plate, (which isn't necessarily the case), then this has 15 jewels; 5 for the balance, 2 for the pallets, then two each for the lever, escape, 4th, and 3rd wheel pivots.
    "Ut tensio, sic vis" - Robert Hooke
  1. Antique Silver Calendar Pocket Watch Looking for any Information
    By gshep in forum European & Other Pocket Watches
    Last Post: 09-25-2015, 04:45 AM
  2. Early 300 Beat pocket watch. Help with identification!?!?!?
    By AGBlex in forum European & Other Pocket Watches
    Last Post: 12-12-2012, 11:34 PM
  3. 1850'ish English Pocket Watch Help with Hallmarks
    By Louis Sicona in forum European & Other Pocket Watches
    Last Post: 12-22-2011, 04:52 PM
  4. antique silver ladies pocket watch
    By riaz in forum European & Other Pocket Watches
    Last Post: 04-17-2010, 12:05 PM
  5. Geneve pocket watch help with dating this piece
    By newport74 in forum European & Other Pocket Watches
    Last Post: 04-19-2008, 02:36 PM
