    Default Recommendations for best CAD programs suitable for clock construction
    Hello everyone, I have just recently joined the NAWCC, and this is my very first post on this forum.
    I am just starting out in clock construction, and my goal in future is to construct skeleton clocks in traditional materials such as brass and steel. My primary interest is in skeleton table clocks, with fusee and power maintaining devices, etc.
    My question to forum members is; Can any of you recommend a specific CAD program which is well suited for clock construction?
    I would like to be able to produce scale drawings for the purpose of producing paper templates, make renderings and simulations, etc, however, I do not necessarily require a program capable of creating tool pathing, as my intention is to machine all the components using a lathe and vertical mill, etc (no CNC).
    Ideally, I would like the possibility of creating cycloidal tooth profiles that match commercially available gear cutters for teeth and pinions (perhaps some CAD programs even provide this feature?)
    From what I have seen from different web articles, Autodesk Fusion 360, Autodesk Inventor, Rhino for Mac, Medusa 4 Personal, KeyCreator 3D and TurboCad Professional V6, appear to be suitable for designing mechanical clocks, however, I do not know enough about CAD to be able to determine which program is best suited.
    Can anyone give me their recommendations, and if you have personal experience with several CAD programs, but have a preference for one program over the others, would you be kind enough to share your reasons?
    Any advice would be greatly appreciated, as this is a completely new field for me.
    Best wishes, Paul.
    Default Re: Recommendations for best CAD programs suitable for clock construction (By: Paul Madden)
    Welcome Paul -- I started out using AutoCad 25 or so years ago, and upgraded a few times over the years. However, I switched to Rhino about 5 years ago, and like it very much. There's a pretty steep learning curve with either, as they are both very powerful programs. I switched because the upgrade would have been prohibitive when I changed to a 64 bit computer, and my old program wouldn't load. Since then, ACad has changed to the subscription program (Fusion 360), which isn't as big a one-time bite.
    I'm completely happy with Rhino - the user interface is much better than at least the old AutoCad. Either one will make your life a lot easier in fabrication, even if you don't go the CAM and CNC route, and will be worth the effort to learn CAD. There are probably some others who will recommend entry-level programs, which would probably be entirely sufficient for your purposes, as well as being cheaper or free.
    Many years ago, a programmer friend wrote a script to generate true epicycloidal curves in ACad. This was an interesting exercise, but never made much difference at the magnifier-and-file level. I probably have it around somewhere.
    John MacArthur
    Default Re: Recommendations for best CAD programs suitable for clock construction (By: John MacArthur)
    Dear John,
    Thank you so much for your input. Its very useful to receive advice from people who have hands-on experience.
    As I have no CAD experience whatsoever, any program will be a learning process for me. I am wondering if there is not an entry-level program that exists which could get me started, and makes transitioning to a more powerful program a little easier. (I have heard some programs offer both 2D and 3D, which is perhaps intended for this reason?)
    Thanks for providing a comparison between between the AutoCad and Rhino programs. I really appreciate it John.
    Best wishes, Paul.
    Maybe someone else will step in - I'm sure there are some simpler ones out there.
    Johnny
    Paul,
    Most CAD software will have a pretty steep learning curve because they have a huge number of commands and it takes some practice to become proficient.
    I currently use Draftsight. It uses the same commands as Autocad and will load or create Autocad files. You can download it HERE for free. You will need to register it once each year to keep it active, but that only requires you to provide an email address. They also have quite a few tutorials on Youtube to get you started.
    See this thread or this thread for more information on drawing cycloidal wheels.
    Allan
    Default Re: Recommendations for best CAD programs suitable for clock construction (By: Allan Wolff)
    Dear Allan,
    Many thanks for your recommendation. I will definitely research this program further. Also, thanks for directing me to the thread on cycloidal wheels.
    Best wishes,
    Paul.
    Apr 2013
    Linköping, Sweden
    1,770
    I've found Solidworks to be both intuitive and very useful. It even features physics simulations allowing you to run a Clock and check for clearances and impulse angles.
    Default Re: Recommendations for best CAD programs suitable for clock construction (By: karlmansson)
    Hi Karl,
    I have also read several positive reviews on Solidworks. I can imagine the possibility of making physical simulations, as many CAD programs do, is one of the primary advantages of CAD over traditional drawing.
    Thanks for taking the time to give your input, I really appreciate it.
    Best wishes in the meantime Karl,
    Paul.
  1. Replies: 3
    Last Post: 02-26-2016, 05:22 PM
  2. Replies: 1
    Last Post: 12-25-2011, 12:04 AM
  3. Elliott 9 Tube Longcase Clock - Help for best sounding chime!
    By Christopher Isaac in forum Clock Repair
    Last Post: 02-08-2008, 06:41 PM
  4. Looking for New Haven 8 day Auto Clock
    By Kimo in forum Clocks General.
    Last Post: 05-23-2006, 06:57 AM
  5. Looking for info on Levi Hutchins Grandfather Clock
    By chasbaz in forum Clocks General.
    Last Post: 10-07-2005, 01:20 AM
