Results 16 to 18 of 18
    Default Re: ITR master clock, contacts worn. (By: Peter A. Nunes)
    Movement is finished and has been running well, manually wound, for a couple of weeks now. Power supply has arrived, now to figure out how to hook it up.
    NAWCC 25131
    5,597
    Peter I am not into these time pieces, but it sure looks awesome. Well done.
    Quote Originally Posted by David S View Post
    Thanks, David, it's been a satisfying project.
    NAWCC 25131
  1. Stromberg 45 Master Clock contacts
    By K Reindel in forum Electric Horology
    Last Post: 04-14-2007, 08:59 AM
  2. ITR Master Clock
    By time327 in forum Electric Horology
    Last Post: 03-30-2006, 10:29 AM
  3. Need picture of a movement from a Model A ITR master Clock
    By Joe Gensheimer in forum Clocks General.
    Last Post: 10-18-2004, 09:18 AM
  4. IBM/ITR Master Clock
    By Datamath in forum Electric Horology
    Last Post: 06-05-2003, 11:31 PM
  5. Adjustment of ITR master clock
    By lperzy in forum Electric Horology
    Last Post: 04-02-2003, 08:49 AM
