Goal: $300, Received: $165.00 (55%) Contribute Now
Results 1 to 5 of 5
    Default Kelbert chronograph with valjoux 72
    i am not able to find anything on this KELBERT and I think it is a Valjoux 72 or a derivate column wheel; I need help with identifying both the maker, the age and the right movement; it ticks great, keeps time but the pushers do not respond even though the chrono central hand is moving smoothly and the pushers go in and out easy; it seems to be needing a service and adjustments; the watch is untouched as I found in a watchmaker's estate, nothing seems to have been redone or worked on, the dial is original and untouched, the hands move nicely; I am not sure about the crown, it looks to be of age but not sure if original; the case is 34mm x 40mm from lug to lug and 12.5mm thick with 18mm lugs.
ID:	341675   Click image for larger version.
ID:	341676   Click image for larger version.
ID:	341677   Click image for larger version.
ID:	341678   Click image for larger version.
ID:	341680   Click image for larger version.
    Default Re: Kelbert chronograph with valjoux 72 (By: Paul Carahan)
    Hi Paul, this movement is not a cal 72. It looks to be a Valjoux cal 77. Probably dates from mid 40's to mid 50's. Looks like it needs a good clean.
    Default Re: Kelbert chronograph with valjoux 72 (By: captainscarlet)
    thanks captainscarlet, do you have any info on "Kelbert"? I found great looking watches, very valuable, but not much on the maker...
    Hi Paul. No I don't have any info on Kelbert. Looking at the code on the Balance bridge, I would imagine they were a US importer rather than a manufacturer. Google may have the answer
    Technical Admin Tom McIntyre's Avatar
    Aug 2000
    Boston. MA USA
    19,311
    Blog Entries
    10
    Just to avoid confusion. The item in question is a chronograph wristwatch. It is not a chronometer, even in the wrist chronometer sense. It will probably get a better respons in the wristwatch forum. I would be happy to move it there if you like.
    Tom McIntyre Click me.
    If you don't learn to laugh at trouble,
    you won't have anything to laugh at when you're old.
    Will Rogers
  1. 1940s TELL Chronograph with Valjoux 22
    By Paul Carahan in forum Wrist Watches
    Last Post: 03-31-2017, 06:05 AM
  2. Chronometry: 1940s TELL Chronograph with Valjoux 22
    By Paul Carahan in forum Chronometers
    Last Post: 03-27-2017, 08:00 PM
  3. Help with Valjoux 72
    By Bryan Eyring in forum Watch Repair
    Last Post: 12-28-2009, 08:27 PM
  4. Hamilton chronograph with Valjoux 72???
    By pdaneu in forum Wrist Watches
    Last Post: 12-27-2006, 07:59 AM
  5. Congrats - The Valjoux 72 with a brief history of Valjoux
    By Marty Rougeaux in forum Wrist Watches
    Last Post: 02-21-2001, 03:10 PM
