Goal: $300, Received: $250.00 (84%) Contribute Now
Thread: quail problem
    Aug 2005
    southwest Kansas.
    341
    Default quail problem
    I'm working on a cuckoo/quail and somehow or someone, removed the loop on the end of the lift for the quail. Just wondering how would be the best way to repair this. I've thought about it a lot, but would like your input. Thanks!
ID:	340834   Click image for larger version.
    Default Re: quail problem (By: CJo)
    If memory serves, that lever should interact with and lift the long loop on the other side. I believe that's what activates the cuckoo after the quail call. You could use a tube to solder on an extension to what you have, or make a new wire.
    Default Re: quail problem (By: shutterbug)
    There is a video on Youtube of your movement that shows the part, I found it while looking for info on my quail cuckoo: https://www.youtube.com/watch?v=Dhde6rx3F2A As shutterbug suggested the easiest approach is to solder a tube and extension piece in place.
    13,641
    One always wonders why people do such things
    "Dang, I hate this wire. I'll snip it off. There, I feel much better."
    Default Re: quail problem (By: Tinker Dwight)
    I guess the previous owner really hated the chirping sound from the quail...
    Sometimes things people do defy explanation. I restore a lot of vintage ham radio gear from the 1930s and 1940s and one of the really nice looking radios from that era is the National NC-100X with an art deco silver, black, and red front panel with a green "magic eye" tube. I picked up one for a parts unit because a previous owner not only drilled a hole through the front panel for an added control he chose to drill it right through the styled National diamond logo.
    Apr 2006
    western PA.
    167
    Default Re: quail problem (By: nsc5)
    The OP is correct . The loop end has been cut . That top lever is not the cuckoo trip lever . The video cited gives the form and length of wire needed . Cuckoo trip lever is further down the wheel train .
    Registered User THTanner's Avatar
    963
    I have had three cuckoo clocks so far where the owner cut off the tail flip wire "because it was in the way"
    You miss 100% of the shots you don't take. - The Great One
    13,641
    Default Re: quail problem (By: senhalls)
    Quote Originally Posted by senhalls View Post
    That cut one is just for the bellows. The long curved brass lever is pushed down by the pins sticking out
    of the quail's count wheel and is what trips the cuckoo. It is clearly seen in the picture.
  1. Cuckoo/ quail problem
    By harold bain in forum Clock Repair
    Last Post: 09-03-2009, 11:15 PM
  2. Enfield Mantle Clock problem
    By Kate in forum Clocks General.
    Last Post: 11-10-2006, 06:27 AM
  3. Strike , run time problems corrected
    By Seth Thomas Fan in forum Clock Repair
    Last Post: 05-14-2006, 12:24 PM
  4. Bushing problem
    By jacks61fd in forum Clock Repair
    Last Post: 09-15-2003, 01:30 AM
  5. Setting Problem
    By Kent in forum American Pocket Watches
    Last Post: 06-07-2003, 02:27 PM
