Goal: $300, Received: $215.00 (72%) Contribute Now
Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
  1. #31
    Registered user. RJSoftware's Avatar
    Apr 2005
    Loxahatchee, Florida
    7,598
    Default Re: Why is this hairspring off center? (By: Rob P.)
    Yep.
    Quote Originally Posted by Rob P. View Post
    Unless the difference is the direction of the coils or location of the roller jewel, what I would assume, for flat springs with no overcoil, is that the pinning point on the collet should be perpendicular to the final pinning point on the stud. Which point (90 or 270) on that perpendicular line probably depends on who designed the movement more than anythign else.
    I think we're jumping ahead of ourselves here. At this point all we know is that the HS is deformed.
    Good clocks always know the time, that's what they tell.
    Bad clocks get glued with macaroni, in Steampunk Hell.
    Ahh, the crunchy sound of victory https://www.youtube.com/watch?v=NGaVUApDVuY
  2. #32
    Registered user.
    Apr 2013
    Linköping, Sweden
    1,911
    Blog Entries
    That's true. I think I was overly pessimistic about the spring not having enough space, looks like it could fit just fine.
    The discussion turned into more of a theoretical one. Nonetheless, I think it's important to know all the aspects of why a hairspring works like it does before adjusting it. It doesn't answer the OPs question but it adds to the context.
  1. power indicator/reserve why is this not common?
    By Watchfixer in forum Watch Repair
    Last Post: 11-01-2011, 02:25 PM
  2. What is this hairspring movement?
    By Gage Rosti in forum Your Newest Clock Acquisition
    Last Post: 08-07-2011, 09:27 PM
  3. Why is this listed as 'Special'?
    By Nick23 in forum American Pocket Watches
    Last Post: 01-20-2011, 06:33 AM
  4. Is this hairspring correctly placed?
    By Sir_Walton in forum Watch Repair
    Last Post: 08-24-2009, 02:45 PM
  5. I'm curious - Why is this clock so expensive?
    By Spaceman Spiff in forum Clocks General.
    Last Post: 10-23-2008, 12:24 PM
