Goal: $300, Received: $115.00 (38%) Contribute Now
Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Registered user.
    Oct 2010
    13,351
    Default Re: Waltham Regulator Loses Power (By: shutterbug)
    I'll admit it can be confusing but it is right. The cable on the drum winds
    the maintenance spring in the direction of run while the winder lifts the
    weight in the opposite direction of run.
    I always have to think about it some my self to justify how it works.
  2. #17
    Default Re: Waltham Regulator Loses Power (By: ChrisBeattie)
    Back to the basics. Do all of the arbors, including the mainwheel arbor, have end shake and do you have good locking at the e-wheel with a nice sharp edge at the ledge where the dead face transitions to the impulse. You should have easily noticable over-swing, after the e-wheel tooth drops onto the dead face it should slide up the face for a short distance before starting back toward the impulse face. If your weight is to light, your clock will never run properly. Did you weigh your weight yet?
    Also, do those two weight pullies match? Seems a little odd that a 6' long clock would need that extra pulley.
  3. #18
    Registered User ChrisBeattie's Avatar
    Dec 2004
    Canandaigua, NY
    238
    Default Re: Waltham Regulator Loses Power (By: Willie X)
    Hello all,
    Thank you all for the ideas and items to check. I do believe the weight is 6 or 7 lbs. but will check to be sure. I don't think there is any "rubbing" of the cord anywhere as I looked for that issue to ensure that wasn't the problem. I also did check the end shake of all arbors and do have a bit of over-swing. Not drastic, but noticeable slightly. I have oiled the pallets and also the pendulum rod where it meets the crutch. I do think the Geneva stop was ok and not part of the issue, but now you have me second guessing so I will re-look at that. I am pretty sure that when it stopped the Geneva stop was not engaged with other teeth, hence not even touching. The clock is at a friends house and I will get to it as soon as I can but work for a college and we are within a few weeks of graduation. Busiest "time" of the year .
    Thanks again for the great ideas, I will get back soon. Regards,
    Chris
    So Many Clocks, So Little Time
  4. #19
    Registered user.
    Oct 2010
    13,351
    Also look to see if the stop is hanging. The
    fact that the maintenance ratchet was loose indicates
    that the drum wasn't being allowed to turn.
    Other than the cable being jammed, I can't think of anything
    but the stop causing the issues.
    Does the lower gear of the stop turn freely? It should
    have some resistance. I believe it should have a light wavy
    washer under it. The vibration of the movement might shift
    it to a point that is jams the arbor.
  1. American Pocket Watch Source for Waltham regulator
    By RON in PA in forum Watch Repair
    Last Post: 08-17-2005, 07:58 PM
  2. Ball-Waltham Regulator Spring
    By Brian Durham in forum American Pocket Watches
    Last Post: 07-31-2005, 11:03 AM
  3. Waltham regulator which one
    By lperzy in forum American Pocket Watches
    Last Post: 03-16-2005, 02:12 PM
  4. I deleted the posts on Waltham Regulators
    By ljrusso in forum American Pocket Watches
    Last Post: 12-27-2003, 04:13 AM
  5. Waltham Regulators
    By Snide in forum American Pocket Watches
    Last Post: 03-09-2001, 12:42 PM
