Results 1 to 7 of 7
    Default Cuckoo Disassembly
    First time working on cuckoos. I need info on how to disassemble it. See photo.
    The 2 bellows boxes are GLUED (blue arrow) to the sides of the thin plywood case. In order to access the 4 mounting screws (red arrows) and remove the movement, it appears that I must pry apart these 2 wooden glue joints holding the bellows, then remove the bellows. This seems very destructive to me and likely to split the plywood sides. Is there an alternative, or a way to "soften" the glue? From a blob that oozed out just below the bellows, it appears to be carpenters wood glue .
    Thanks
Name:	2017-04-13 17.25.43.jpg
ID:	340115   Click image for larger version.
    Default Re: Cuckoo Disassembly (By: gocush)
    Yes, the whistles are glued to the case on many newer cuckoos.
    To remove them use a small thin (but dull) knife, start at the bottom and when you get the blade in between the whistle and case a bit, twist it and the whistle will pop right off. Sometimes it will separate cleanly, sometimes a small area of the plywood case will pull out.
    I always clean this glued joint as well as I can, so the whistle can be replaced using the traditional single screw flat head wood screw and small brad/nail.
    Hope this helps, Willie X
    1,525
    Default Re: Cuckoo Disassembly (By: Willie X)
    Quote Originally Posted by Willie X View Post
    As above. Yes.
    Default Re: Cuckoo Disassembly (By: roughbarked)
    To remove the bellows a knife as suggested works well. I use a narrow putty blade which is like the knife. Another help is to use a heat gun or torch to heat the blade which will allow it to soften the glue faster and generally pops off without pulling any plywood off the case.
    Hope both ideas help you. Jay
    410
    Default Re: Cuckoo Disassembly (By: James Holloway)
    I just had one of these. The bellows popped out when I braced a kitchen knife against the bottom of the case and levered the sharp edge of the blade between bellows and case. I found it helpful to mark the positions of the whistles so they go back in the same place.
    http://www.lancastereaglegazette.com/search/kinsler/
    Default Re: Cuckoo Disassembly (By: kinsler33)
    a. Pry the whistles off.
    b. Remount them with the screw and the nail.
    I've never seen serious damage to a cuckoo clock by prying off glued whistles.
    Is what I think.
    It's possible that your doesn't have the screw and pin that has been mentioned. If not, it's just a small screw that goes through the case into the bellows tube roughly half way between the top and bottom ( a bit lower might be better), and a small pin inserted the same way at the upper end to keep it from moving. Don't use glue when re-installing.
  1. Cuckoo Clock Squeak
    By kirklox in forum Clock Repair
    Last Post: 01-24-2014, 10:53 PM
  2. Cuckoo Disassembly Question
    By blueloon in forum Clock Repair
    Last Post: 02-28-2012, 10:10 PM
  3. Cuckoo disassembly help
    By rowiac in forum Clock Repair
    Last Post: 02-22-2007, 04:48 PM
  4. Regula Cuckoo BPH
    By Colin d in forum Clock Repair
    Last Post: 12-14-2006, 12:35 PM
  5. Cuckoo WIRES question
    By bangster in forum Clock Repair
    Last Post: 05-01-2005, 11:12 AM
