Goal: $300, Received: $165.00 (55%) Contribute Now
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 31
  1. #16
    Default Re: Gustav Becker clock (By: John Hubby)
    Quote Originally Posted by John Hubby View Post
    Mario, thanks for the additional movement photos, those are quite helpful and I will provide a date and other information in my next post. Do you have a case for the clock? I had asked for photos of the case, also the gong so we can do a complete documentation.
  2. #17
  3. #18
  4. #19
  5. #20
    Default Re: Gustav Becker clock (By: mariosthegreat)
    Mario, you can add multiple pictures to one post. It would help to keep things more manageable on the BB
  6. #21
  7. #22
    Exclamation Gustav Becker clock (By: mariosthegreat)
    The beat of my clock isn't stable. It goes up and down. The pendulum
    Stops many many times.
    I took off the pendulum still the problem of the beat.
    Pl. Help.
  8. #23
    Still waiting for your information on the clock please.
  9. #24
    Registered User wow's Avatar
    Jun 2008
    Pineville, La. (central La.)
    2,028
    Default Re: Gustave Becker clock (By: mariosthegreat)
    Is this the same clock you already posted about, or a different one. We need more details.
    Will Walker (WOW)
  10. #25
    Apr 2002
    20,118
    Blog Entries
    Default Re: Gustave Becker clock (By: wow)
    Has it been serviced recently.
  11. #26
  12. #27
    Registered user.
    Oct 2010
    13,627
    What is it you wait for? We have asked for pictures
    of the from of your movement. We've not seen these yet.
  13. #28
    Principal Administrator John Hubby's Avatar
    Sep 2000
    The Woodlands, TX
    11,156
    Mario, thanks for the additional photos. However, please note that you can post up to 10 photos in each post, which makes it much easier for us to see what you are presenting. If you need assistance for this there is an instruction thread at the top of each forum how to use our photo posting system.
    I was hoping the photo of the back of your movement would be clear enough to see the serial number, however I presume the actual number is what was written on a paper that you posted. Based on that serial number, your movement was made in the January-March quarter of 1904. I notice the pendulum length stamp (P 65.5) on the back of the movement shows it is 65.5 cm long, which indicates this movement was most likely made to be mounted in a large Vienna regulator case instead of a medium size grandfather case.
    It appears that the case for your clock was made by a craftsman or hobbyist (not by the GB factory) some time later than the movement was made. It is a traditional design and has a generally pleasing appearance, however there are not any designs like this one in any of the GB sale catalogs available. There are a number of indications of hand-made assembly and finish; for example the mounting of the movement support bracket is on a raised plank of modern grooved wood and not directly on the back board of the case. The dial also appears to be from a later period than the movement, likely by 20-30 years. However, the hands are correct and fit the dial.
  14. #29
    Yes it is.
    - - - Updated - - -
    Yes
  15. #30
    Jun 2008
    2,028
    Quote Originally Posted by mariosthegreat View Post
    Yes it is.
    - - - Updated - - -
    Yes
    Mario, your clock has a beat adjuster at the bottom of the crutch which is adjusted almost as far as it will go to one side in your photo. I would adjust it back to the middle of the crutch and then set the beat by holding the pallets with one hand and gradually moving the crutch, allowing it to slip on the arbor, until the clock is in beat. When it is in beat, you will hear the tick at approximately the same distance from the center of the pendulum swing on the left side and the right side. Once you reach that point, it is easy to adjust the beat with that adjuster on the bottom of the crutch. It should keep running once you get it perfectly in beat.
    Will Walker (WOW)
  1. Post Your Gustav Becker Clocks Here
    By Mike306p/Ansoniaman in forum Clocks General.
    Last Post: Yesterday, 10:51 PM
  2. Need help Gustav Becker clock information
    By joeZy in forum Clocks General.
    Last Post: 09-21-2006, 07:21 AM
  3. Identify this Gustav Becker clock?
    By annelie in forum Clocks General.
    Last Post: 07-23-2006, 08:51 AM
  4. Gustav Becker clock dating by serial number.
    Last Post: 05-11-2005, 10:18 AM
  5. Gustav Becker clock
    Last Post: 02-28-2003, 01:06 AM
