Goal: $300, Received: $370.00 (124%) Contribute Now
Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
  1. #16
    Default Re: Elgin A-8 Bomb timer (By: River rat)
    I just pulled the sweep second hand off a 4992b and the shaft that the hand fits on measures. 0.23 mm.
  2. #17
    Default Re: Elgin A-8 Bomb timer (By: NC Plumber)
    Quote Originally Posted by NC Plumber View Post
    And I just checked one of my Elgin Timer parts movements, and the post measures 0.25mm. I
    'd be very cautious in installing it. Some of the parts movements I have, the only real problem is the post is broken off the sweep seconds pinion. Perhaps pushing the hand onto the post carelessly? But a too-small pipe can also lead you to pushing too hard.
    The thing is, the pipe has to be a tight fit. The flyback is abrupt, and if the hand doesn't fit TIGHTLY, it will slip, and not return accurately to 0:00.
  3. #18
    Default Re: Elgin A-8 Bomb timer (By: GeneJockey)
    Learned something knew about these Elgin timers today, I have a couple and one in parts box. The running ones I have all had the large balance, checked the one in parts and its the small wheel Jitterbug style- had to look with a loop. I guess I always thought someone had robbed the balance wheel out of it all ready. Its incomplete, missing crown and the large hand in middle ( I used it for one of my others), also sadly the hairspring is twisted and staff bad. If original poster needs the center pinion let me know I think its ok on this one or can check.
  1. Elgin "German Time Bomb" running fast
    By wauslh in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 11-22-2011, 11:59 AM
  2. Elgin German time bomb 400 day clock
    By narrowfarm in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 08-19-2010, 02:28 PM
  3. Elgin 582 60 Second Timer
    By matt_greenwood in forum American Pocket Watches
    Last Post: 06-10-2009, 04:08 PM
  4. INFO ON ELGIN 18S RAILWAY TIMER
    By DEVILDOG76 in forum American Pocket Watches
    Last Post: 06-10-2005, 03:41 PM
  5. Elgin Bomb Timers 15 J
    By tiger in forum American Pocket Watches
    Last Post: 08-20-2002, 07:41 AM
