    Registered user. rstl99's Avatar
    Oct 2015
    Ontario, Canada
    217
    Default Bergeon 30402 question (balance screw cutting tool)
    I bought some used watch repair tools yesterday and in the pile was a Bergeon box containing a 30402 balance tool cutting tool, with the two cutters. It's in nice shape. There is no manual with it, it's fairly self explanatory, but I can't figure out what is the purpose of the tapered pin that one can screw vertically into the base.
    I'd appreciate someone educating me on this. Thanks.
ID:	339893   Click image for larger version.
    6,852
    Default Re: Bergeon 30402 question (balance screw cutting tool)
    Hi Robert,
    That's a balance tack which holds the cock up out of the way whilst the balance is being worked on. It means you don't have to remove the balance from the cock.
    Oct 2015
    Ontario, Canada
    217
    Default Re: Bergeon 30402 question (balance screw cutting tool) (By: gmorse)
    Hi Graham,
    Oh I see, yes that makes sense. Thank you very much for clarifying this for me. Time will tell whether I will use this tool or not to shed mass from balance screws (I gather from DeCarle that not all watchmakers favour this approach), but Bergeon tools are always such well thought out and manufactured little objects.
    In the parts and tools I acquired was a box containing 12 vials each containing small washers to add weight to balance screws, so I'll need to educate myself on when to add weight vs when to remove some!
    Cheers,
    --Robert
    6,852
    Default Re: Bergeon 30402 question (balance screw cutting tool) (By: rstl99)
    Hi Robert,
    Adding weight will slow it down, removing will speed it up, but remember that the former is reversible but if the latter removes metal from the screws, and you overdo it, will require the addition of timing washers! Substituting lighter screws is a non-invasive way of reducing the weight. This is separate from poising or temperature compensation considerations.
    Not only don't overdo it, but stop and ask yourself why you are removing weight before doing so. Make sure you aren't just compensating for some other fault by removing (or adding) weight. The watch left the factory with a given balance weight and timed correctly. Ask yourself what changed between then and now.
    1,525
    Default Re: Bergeon 30402 question (balance screw cutting tool) (By: Dave Coatsworth)
    Quote Originally Posted by Dave Coatsworth View Post
    It is a good comment.
    Oct 2015
    Ontario, Canada
    217
    Default Re: Bergeon 30402 question (balance screw cutting tool) (By: roughbarked)
    Yes indeed very insightful and thoughtful comments, I appreciate you both for sharing the knowledge.
    Well I suppose it's nice to have that tool and those washers if/when I should ever need them, and to have a better idea now how and when to use them.
    Thank you again.
    1,525
    Basically, these are factory tools. ie: for people who make watches.
    Quote Originally Posted by rstl99 View Post
    Thank you again.
    Better to have a tool and not need it than to need it and not have it. That's the way I look at it also.
    Robert
  1. balance screw undercutters
    By 107WestStreet in forum Horological Tools
    Last Post: 12-16-2005, 12:26 PM
  2. BALANCE WHEEL TRUING TOOLS
    By o.c.kid in forum American Pocket Watches
    Last Post: 12-06-2003, 12:14 PM
  3. Balance Screw Scales
    By Wynter Sturtevant in forum Horological Tools
    Last Post: 01-29-2003, 04:27 AM
  4. Balance screws loose?
    By GlennB in forum American Pocket Watches
    Last Post: 02-14-2002, 06:45 AM
  5. Vigor Balance Screw Holders...
    By Steve Maddox in forum Horological Tools
    Last Post: 09-12-2001, 06:24 AM
